LUMINA by Design_Master
All about overclocking and modding techniques, how-to's and worklogs.
Moderator: CM Moderator
Postby Design_Master on Sat Dec 01, 2007 2:30 am
Hi modders! :D
I am going to present to you my most recent mod project named LUMINA, which was entirely designed and built by me from smoked and crystal acrylic shapes. It demanded me a very hard work and skill for creating and mounting 114 pieces, through precise cuts, polishes, finishes and heat moldings procedures.
The following result come from my untiring seek for the best design, lighting and 6 mouths of hard work.
Feel free to comment! I really hope you enjoy!
Project
The first step for starting the project was to design and mount all the case structural parts. All the other complemental parts would be made in a second stage. The project combines an amount of 114 acrylic pieces, with 14 structural ones and 100 complemental ones, both smoked, crystal or foggy and reaches the following dimensions: 520mm height x 285mm width x 545mm length x 2-15mm thickness (considering thumb screws and foot stands).
Mounting
For mounting all 114 pieces of LUMINA project, I performed the cuts, moldings, finishes and polishes procedures manually by using the Rotary Tool kit, sandpapers, drill, soldering irons and aluminum heat molds. I only requested the factory to mold some of the 14 structural pieces because of my technical impossibilities of molding big size parts.
Below, the structural parts being placed:
After some days of planning, I decided to create a new PCI board placement system. My idea was to build a back door system to get the boards insertion easier and with screwless.
No problem with the acrylic powder: All boards used here are wasted! :)
By using the Rotary Tool, I performed precise cuts to create slot bays on the shape. Below, the parts already mounted and set firmly in place by two hinges and the slot plate rail piece, built from smoked acrylic by using heat mold. Later on I will show you some examples about this molding procedure.
On the mainboard fixing shape, I did two 80mm diameter holes for improving internal air circulation. This part is located internally, without any external contact. To fix the mainboard I made ten acrylic cubes, replacing the screws:
The next step was to build the main panel by using a 12mm acrylic piece. I had to sculpt each button hole manually to reach the desired form. It was very very hard-working and took me 3 days:
At that moment, the parts faces would still be sanded in view of the fact I had planned a foggy finish for reaching a better lighting effect:
After making up the part, I firmed the main panel leds and switches with cold-heat glue. To hide the apparent wire, I idealized and made a new part following the original lines of the main panel:
That’s an acrylic cut shape completely molded by using the heat mold:
That’s the finished piece with rounded corners:
Observe the foggy finish on both parts and how well mixed they are, don’t you think? The cable sleeving was made from nylon nettings. Later on you are going to see more about it:
Returning to the case, I made some draughts seeking the best design for the complemental parts of the recently placed lateral windows. On the front face, the holes for placing the main panel had already been done:
In focus, the engineering solution for fixing little curvatures of very thin parts, such as the 4 structural angle columns built from smoked acrylic. All of them were firmly linked on pressure through two screws by each extremity, ensuring the stability and rigidity of portico:
Finally, the last external part was installed. That’s an angular smoked window, with one central groove and fixed in place by two hinges. Following the project, this part was provided by the factory because I didn’t have a big heat mold needed, unfortunately:
The 2mm smoked shapes were being prepared to be turned into lateral windows complements:
The cuts had to be done carefully because of their curvatures. The parts were properly sanded and polished:
Above, the smoked complements were fixed on the inside windows. Below, I idealized an air filter by using 0.5mm double layered metallic netting. For that, I cut two 120mm diameter wheels and placed them side by side surrounded by “Uâ€
LUMINA's Official Worklog:
http://luminacasemod.110mb.com/
User avatar
Design_Master
Aerogate Geek
Postby Design_Master on Sat Dec 01, 2007 2:41 am
The next step was to modify the LUMINA VGA. I planned a complete redesign of the Radeon X1950 PRO cooler for making it as well worked as the entire project. Following, some drafts I did which inspired the final project:
I got started with the cooler cover. Holding the definitive project, I placed the old cooler on 2.5mm smoked acrylic shape for marking.
After that, I made two 90º angle folds on acrylic shape by using the heat mold...
...And lateral cuts following the desired design. I also projected the protection parts that would be fixed on corners of the cooler cover.
Take a look at the cuts of the cooler cover apertures and corner protection parts that were done by using the rotary tool. On these last ones I would still make a foggy finish.
The heatsink with heat-pipe system was the only remaining device from the old cooler that I decided do keep up. Below, the cooler cover already polished and finished.
After that, I started preparing the VGA fan for being placed within the cooler cover. After some cuts, an 80mm fan was opened laterally to allow a free air flow…
…And the lighting circuit was remade to install two blue leds parallelly positioned.
I couldn’t forget an indispensable part in this modding. Through exhaustive cutting, paring and molding acrylic procedures, I reproduced the original slot plate. It’s cool, don’t you think?
All of the self adhesive details were done by manual cutting.
That’s the LUMINA VGA! I think I built a monster that reaches 3 PCI SLOTS!!! It measures 62mm height, excluding the screws! Visit the main gallery for more details. :shock:
The power supply unit couldn’t be kept out of modding. By cutting and molding an acrylic shape, I built a crystal box with one open face. After that, I made some cuts for fans windows, cables access, voltage switch, and power plug connector:
Always seeking for an original design, I chose the foggy finish for up and front faces, also crystal, smoked or brushed steel finishes to any other part.
The front and under fan windows were protected by metallic netting and a 120mm grill, respectively.
Following, the PSU box was ready for internal devices installation.
In view of the lack of free space remained by PSU board heatsink , for a 120mm fan, I decided to use one Cooler Master 80mm blue led fan to be installed next to the metallic netting.
The board was removed from my old 550W PSU, new cable extensions were created and all wires were covered by cable sleeving.
The self transparent adhesive paper was firstly printed on laser printer before being placed on any target surface. That also includes other textured self adhesive paper such as the gold CM logo below, a double layered adhesive.
Below, you can see some of self adhesive papers used in the project:
The last pieces I made were two DVD drive bay borders:
User avatar
Design_Master
Aerogate Geek
Postby Leeum on Sat Dec 01, 2007 2:45 am
Holy moly! :shock:
Tremendous effort and it really shows with the small details. Look forward to seeing more. 8)
Leeum
Aerogate Geek
Postby Design_Master on Sat Dec 01, 2007 2:56 am
Finally, some of the final project pictures:
Overall Look
VGA Mod
PSU Mod
I appreciate very much everyone who has followed my entire worklog until here. If you are in doubt about any described step or missing one, please make me questions. I hope you have enjoyed! :wink:
All the best!!
Design_Master
User avatar
Design_Master
Aerogate Geek
Postby Design_Master on Sat Dec 01, 2007 3:17 am
Leeum wrote:Holy moly! :shock:
Really, Leeum! it was a very hard work for me!
User avatar
Design_Master
Aerogate Geek
Postby X@ndelly on Sat Dec 01, 2007 5:54 am
Congratulations for your I strive & she sweats classification across the board , I am twisting will not only about to you but for everyone the Brazilians that you have pride whereby they do , & knows because we are different? Because we've creativity & we are united. She forces ae , & embraces.
Xandelly - Brasil / São Paulo / Campinas
o_cubiculo@hotmail.com
Parabéns por seu esforço e sua classificação geral, estou torcendo não só para você mas para todos os brasileiros que tem orgulho do que fazem, e sabe porque somos diferentes? Porque temos criatividade e somos unidos. Força ae, e abraços.
X@ndelly
LED Head
Postby raphaelweird on Sat Dec 01, 2007 6:05 am
i just don´t believe!! it´s amazing!! you are making us brazilians proud!!! good luck in the contest!
raphaelweird
LED Head
Postby Design_Master on Sat Dec 01, 2007 6:09 am
X@ndelly wrote:Congratulations for your I strive & she sweats classification across the board , I am twisting will not only about to you but for everyone the Brazilians that you have pride whereby they do , & knows because we are different? Because we've creativity & we are united. She forces ae , & embraces.
Valeu pela torcida, Xandelly!!
User avatar
Design_Master
Aerogate Geek
Postby Design_Master on Sat Dec 01, 2007 6:14 am
raphaelweird wrote:i just don´t believe!! it´s amazing!! you are making us brazilians proud!!! good luck in the contest!
I am very grateful for your words! Thanks!
User avatar
Design_Master
Aerogate Geek
Postby calangojr on Sun Dec 02, 2007 3:50 am
Cara,lindo d+, quando vi pela primeira vez achei q fosse gringo mas depois q vi q era de um brasileiro ,fiquei muito feliz por saber q estamos(vc está) com uma ótima qualidade,porém seu trabalho não esta à alturas deles,esta muito superior ,parabens.
depois gostaria de tirar umas duvidas quanto ao acrilico.
é isso
até mais,estou torcendo por vc.
Londrina/ Pr
calangojr
LED Head
Postby Design_Master on Sun Dec 02, 2007 4:36 am
calangojr wrote:Cara,lindo d+, quando vi pela primeira vez achei q fosse gringo mas depois q vi q era de um brasileiro ,fiquei muito feliz por saber q estamos(vc está) com uma ótima qualidade,porém seu trabalho não esta à alturas deles,esta muito superior ,parabens.
é isso
Londrina/ Pr
I appreciate very much your words! It just keeps me on the way for creating new projects to show the world! Thanks! :D
Amigo Calangojr! Pode ter certeza que LUMINA foi 100% projetado e construído com “tecnologiaâ€
User avatar
Design_Master
Aerogate Geek
Postby danilomenezestorres on Sun Dec 09, 2007 2:48 am
Designer_Master, are you a real Designer or something like that? Because your casemod seems to be absolutely thinked all the single parts.
Congratulations, your work certainly will figure out between winners.
danilo
danilomenezestorres
Aerogate Geek
Postby Design_Master on Sun Dec 09, 2007 5:06 am
danilomenezestorres wrote:Designer_Master, are you a real Designer or something like that? Because your casemod seems to be absolutely thinked all the single parts.
danilo
Thanks my friend! In fact, I am engineer and have already designed some architectonic/structural projects… I think the planning and drawing procedures are the easier part of whole project. Its execution is much harder working, for sure!
All I hope is a fair criterion for who will analyze the projects for voting.
All the best!
User avatar
Design_Master
Aerogate Geek
Postby danilomenezestorres on Mon Dec 10, 2007 3:45 am
I knew it, your wor is very well projected and worked out. Can see the planning work you may did before. Every thing on this case is very well done and finished.
Again congratulations,
danilo
danilomenezestorres
Aerogate Geek
Postby Design_Master on Mon Dec 10, 2007 7:13 am
danilomenezestorres wrote:I knew it, your wor is very well projected and worked out. Can see the planning work you may did before. Every thing on this case is very well done and finished.
danilo
Thanks again, Danilo,
I think the resume of my project planning has been posted above already. I could not join all my handwritten drafts, because it would spend a lot of pictures.
All the best!
User avatar
Design_Master
Aerogate Geek
Next
Return to Modding & Overclocking
Who is online
Users browsing this forum: No registered users and 2 guests
cron
