Usable hardware: Pentium D 930, Gigabyte GA-965P-DS4, 2GB Kingmax 800MHz DDR2, GigaByte MAYA GV-NX76T256D-RH 256MB, WD CAVIAR 640GB AAKS, Lite-On iHas120, Enermax Liberty 500W
CM hardware: CM GeminII + 4x fans R4-S2S-12AK-GP
This project is a miniature of a truck Avia DA-12 used by some fire brigade departments. It is reduced to a scale of 1:8 and is an exact replica of one used by our local fire department.
The whole construction has been made by myself in my small workshop at home with the use of a vice. I used 1.3 mm thick sheets of steel. These were welded into the basic shape of the Avia truck, consisting of the cab and the rear body. The main tools used for this proces were the grinder and welder. All this was carefully watched by our dog Max.
When the basic construction was complete I could start to carve the necessary openings. A lid was attached to the rear body of the truck, where the hardware would be placed later. I have also made doors for the cab and the rear body and attached all of this to the undercarriage.
