EIZO Complexity Case Mod 2009
All about overclocking and modding techniques, how-to's and worklogs.
Moderator: CM Moderator
Postby Coolone on Fri Sep 18, 2009 12:09 am
Worklog - Part 1 of 2
By Coolone
Cooler Master 2009 Modding Contest
a. Name of mod:
b. Category:
Unique
c. Description of my case / description of your mod entry:
Idea
When my fantastic EIZO FlexScan T68 died I felled very sorry since we already have been friends through 8 years where the EIZO FlexScan T68 monitor have given me the best pictures I ever have seen on a monitor. So I thought this should not be the end of my great EIZO so my imagination was questioned how could I still get anything out of my old monitor, even if it not could deliver any pictures anymore?
Since I like to have a PC case with my one touch I thought it could be nice to make a complex monitor case mod where both PC and LCD monitor is installed in one unit. This was the beginning of my EIZO FlexScan T68 Analog LCD case mod project, where you could see the LCD monitor through the acrylic glass I have build into the front of my old monitor.
EIZO FlexScan® T68 (CRT Monitors)
d. Obligatorily Pictures:
One picture of your final mod entry (preferably 500 x 500 pixels in .jpg file format)
Your mod entry
e. Cooler Master Hardware used for my case mod:
Some description and pictures of the Cooler Master hardware I have used for my EIZO Complexity Case Mod 2009.
Cooler Master LED Silent Fan
2 pieces Case Fan
Cooler Master LED Silent Fan Blue TLF-S82-EB
Image . Image . Image . Image . Image
Cooler Master AEROGATE Fan Control
1 piece Case Fan Control
Cooler Master AEROGATE I ALD-V01
Cooler Master CCFL Light
1 piece CCFL Blue Light
Cooler Master Ultra Aurora CCFL Series DFL-UD1-EB
1 piece CCFL Red Light
f. Homepage:
My homepage for the EIZO Complexity Case Mod 2009.
http://www.lanpartypathfinder.com/casemodding/CoolerMasterComplexity2009/
g. Build phase:
Some pictures from the build phase of the EIZO Complexity Case Mod 2009.
Monitor
Analog EIZO FlexScan T68 monitor split apart
Motherboard tray
Monitor with motherboard tray
Acrylic glass
Monitor with acrylic glass
Monitor with PSU
IBM ThinkVision 6734-AB1 LCD monitor split apart
User avatar
Coolone
Vortex Dreamer
Re: EIZO Complexity Case Mod 2009
Postby Coolone on Fri Sep 18, 2009 12:13 am
Worklog - Part 2 of 2
By Coolone
g. Build phase (Continued):
Analog EIZO FlexScan T68 monitor with IBM ThinkVision 6734-AB1 LCD monitor installed
h. Air flow:
I have installed some FANs in the EIZO Complexity Case Mod 2009 to increase the air flow.
I only measured the temperature by hand and it did not fell any hot! Also the “Monitor” has a meshed surface –
which allows air both seep in / out.
But there will always be some areas with less air flow like in a normal PC case in this case I’m a little concerned
about the area around the hard drives.
I have installed some 80 mm FANs in the EIZO Complexity Case Mod 2009 to increase the air flow
also I have installed a 92 mm exhaust FAN in the top of the monitor mod.
i. Hardware setup:
Motherboard
Gigabyte GA-X38-DQ6
Graphics Card
Gigabyte GV-RX26T256H
Memory
Kingston HyperX DDR2 1200Mhz
CPU Cooler
Zalman CNPS8700 LED
Optical Drive
BUFFALO BR-816SU2 Blu-ray External Optical Drive
Pictures of the hardware setup for my EIZO Complexity Case Mod 2009.
j. Case Mod with hardware installed:
Pictures of the EIZO Complexity Case Mod 2009 with the hardware installed.
k. Case Mod finished:
Pictures of the finished EIZO Complexity Case Mod 2009.
l. Video:
On YouTube you can see a video of the finished EIZO Complexity Case Mod 2009.
EIZO Complexity Case Mod 2009 - Uprising
http://www.youtube.com/watch?v=2QPwkFPGB-E
Also on YouTube there is a video of an earlier version of the case mod without LCD monitor installed.
EIZO Gaming Case Mod 2009 - Daytime
http://www.youtube.com/watch?v=c_5qyojbeKo
m. Thanks for taking a look at my case modding project:
Feel free to comment on my case mod project!
User avatar
Coolone
Vortex Dreamer
Re: Cooler Master Complexity 2009 - CM 2009 Modding Contest
Postby petoscal on Fri Sep 18, 2009 3:19 am
I love this mod!
The fusion between the old monitors and now a whole computer in this space!!, you are not going to paint the monitor in any color right? I think it looks nice like that.
How is your temps?
Really great mod! congrats!
petoscal
Aerogate Geek
Postby Coolone on Fri Sep 18, 2009 4:19 am
petoscal wrote:I love this mod!
How is your temps?
Hi petoscal
Thanks for your words - nice you like my case mod!
Yes. The good thing is that I now got more space on me desk since I not need an external monitor.
Also one thing I did not mention before is the weight of the "Cooler Master Complexity 2009" is less than the original EIZO FlexScan T68 monitor.
Temperature readings from BIOS (PC Health Status)
System Temperature 41^C
CPU Temperature 39^C
CPU FAN Speed 1650 RPM
A lot of heat is coming out of the top of an LCD monitor - this you easily could feel by putting your hand on top of your own LCD monitor. So I here have installed an 92 mm exhaust FAN in top of the monitor.
There is a lot of FANs installed the reason for this is that FANs like to be run at low speed. Nearby all FANs have a point from this on they get really bad noisy. So more FANs at low speed is better than less FANs at high speed.
No. I will not paint it since then the EIZO will lose its original touch.
User avatar
Coolone
Vortex Dreamer
Postby PaPang on Fri Sep 18, 2009 10:51 am
Great Object Mod! True, with this type of mods you should not alter the original appearance IMO too. The hard part is cramming a full pc setup in the spaces and yes, besides being spacious inside, they weighed a ton! Wait a sec, I already commented this same thing in another thread. Is this a ver 2.0? Because it went over the top with the lcd screen!
BTW I use the term "object mod" for anything that is modded that is not a computer case (radio, tv set, r/c car, even a trash can turned into an R2D2!). I think it takes a lot of meticulous planning to do them but yours has besides a superb visual "punch". Kudos! and Good Luck!
Cheers and Saludos,
You arrived in the nick of time for the original deadline.
Kick butt both ways: at the office and at home with Papang BizRigs!
Brought to you from Cancun, Mexico
User avatar
PaPang
Stacker Hacker
Postby Coolone on Fri Sep 18, 2009 7:08 pm
PaPang wrote:Great Object Mod!
Hi PaPang
Yes. This is an new (Uprising - in Command & Conquer terms) version of my case mod, since now I also have installed an LCD in front of the monitor mod.
Under point l. Video: in my Worklog you could see a video of the new version and a video of the previous version.
Also worth to mention is that regarding to the contest rules
http://www.coolermaster-usa.com/microsite/mod_contest09/rules.php
3. ...; please start a new thread even if you have posted information regarding your mod before).
This is the reason to I not updated my old Worklog.
User avatar
Coolone
Vortex Dreamer
Postby FrenkieNL on Sat Sep 19, 2009 1:06 am
Its really nice, Back to the old Mac ! Kuddoos to you ! +1
-= My cases @ casemodz.nl =-
User avatar
FrenkieNL
Vortex Dreamer
Postby chatnoir on Wed Sep 30, 2009 8:13 am
nice work colone congrats :wink:
User avatar
chatnoir
Vortex Dreamer
Postby Cham_E_Lyon TPC on Thu Oct 01, 2009 3:57 am
Great job and very brilliant!
Good luck!
Phils. Street Modder
User avatar
Cham_E_Lyon TPC
Centurion Officer
Postby sunnyXtremist on Thu Oct 01, 2009 7:49 am
GOOD LUCK TO YOU AND TO ALL CONTESTANTS, IT WAS GREAT TO KNOW YOU
sunnyXtremist
Praetorian Soldier
Postby Coolone on Fri Oct 02, 2009 7:32 pm
Thanks to ALL how have visited my Worklog!
And thanks for all the nice words!
Best regards
Coolone
User avatar
Coolone
Vortex Dreamer
Return to Modding & Overclocking
Who is online
Users browsing this forum: MSN [Bot] and 2 guests
