FOR THE FRONT PANEL
I decided to make A Dakota logo or dakota panel for the front.
I needed space to hide the water pump behind it.
- casevp.jpg (169.49 KB) Viewed 1602 times
I took two cosmos front panels apart plus I used my dremel to put them together to make one panel.
I Did not have any sheets of aluminum.
So. I looked around the house and found an old aluminum cooking pan.
I took the pan and cut off the sides.
I used some of my dad's tools and hammered it flat.
Use blue tape to draw out the Dakota on the front.
- casevp1.jpg (215.48 KB) Viewed 1596 times
So once I had it all shaped out and attached to my new plastic mod frame.
I then kept sanding and using primer.
I used flat black spray paint.
- casevp4.jpg (253.49 KB) Viewed 1587 times
I used a small LED orange set from FROZENCPU.COM
attached to the back.
I took the screen and spray painted with burnt orange..so the orange colors will look more orange.
I have a modded picture of it while it is turned on.
THIS IS NOT THE FINISHED PC.
- casevp3.jpg (215.22 KB) Viewed 1585 times
