Project "COOL" (09 Casemod Entry) Complete
All about overclocking and modding techniques, how-to's and worklogs.
Moderator: CM Moderator
Postby jj_sky5000 on Wed Sep 02, 2009 11:46 pm
I was sitting at my desk surfing the web when I came across the Cooler Master casemod contest page. Wow that’s neat. look at all those awesome mod projects. Hmmmm wish I had something to mod. ohhh what’s this on top of my shelf my 1990 (nonworking) Boombox . Image
Maybe I could sell it and get some money too make a Mod. It was in the movie "House Party" with Kid & Play back in the 90's Look in the background http://www.youtube.com/watch?v=uXXpa49fOyU
Lets put it on eBay. Lets see how much one of these go for. Well after more research on eBay I found out that, My boom box will sell for any where between $200 to $1000. It was a collectors items. WOW I cant sell that. So I will just have to update it a little. Put some newer technology in . A duel loop I7 -965 with a pair of 280 gtx's with 7.1 surround sound that should work. But can i get everything to fit. "Sure I can" I don’t think I will be able to put it on my shoulder through.
jj_sky5000
Aerogate Geek
Re: Project 1990 COOl BOOMBOX (09 Casemod Entry)
Postby jj_sky5000 on Thu Sep 03, 2009 12:01 am
09/02/09
Let crack it open and see whast inside
wow thats a lot of stuff.
lets take it all out
a little more
[img}http://farm3.static.flickr.com/2512/3880949835_d115af50af.jpg[/img]
I wonder how big those speaker holes are 190mm how am i going to fill that up. How about a pair of cooler Master 200mm fans that should work.
Lets see what i have laying around to work with.
Well I better start cutting with the dremel.
jj_sky5000
Aerogate Geek
Postby PaPang on Thu Sep 03, 2009 12:06 am
Could be a cool "object" mod entry in the "unique" category. It looks large so you should cram MAYBE a mAtx mobo into it, but wow, those mods take a lot time and planning, not to sure you could make it for Sept 20 , unless you have already advanced on it. Would be a welcome addition for sure.
Cheers and Saludos
Kick butt both ways: at the office and at home with Papang BizRigs!
Brought to you from Cancun, Mexico
User avatar
PaPang
Stacker Hacker
Re: Project "COOL" (09 Casemod Entry)
Postby petoscal on Thu Sep 03, 2009 1:16 am
This mod looks good from the beginning, let's see what happend, the hardware looks nice too.
I hope you can finish it on time.
Cheers! :cheers:
petoscal
Aerogate Geek
Postby nicky_82uk on Fri Sep 04, 2009 3:03 am
sounds cool to me cant wait for some updates :D
User avatar
nicky_82uk
Praetorian Soldier
Postby Maxession on Fri Sep 04, 2009 3:41 am
Hmm, looks interesting, although, I wonder how you'll place that GPU inside on the mobo, seems quite thin the casing...?
Parts shop N-America & Europe | CSX Shop | CM Storm | 2009 Mod Contest
ASUS P5Q-E ~ Intel C2DE8400 @ +4Ghz ~ CM V8 ~ Gigabyte 4850 ~ 2GB Adata 1066Mhz ~ CM M850W ~
CM Cosmos ~ Seagate 500GB ~ Samsung DVD & DVD-RW ~ iiyama 26"TFT ~ Dell 15"TFT
User avatar
Maxession
CM Moderator
Postby sunnyXtremist on Fri Sep 04, 2009 9:26 am
nicky_82uk wrote:sounds cool to me cant wait for some updates :D
me too!
welcome SIr jj_sky5000
sunnyXtremist
Praetorian Soldier
Postby jj_sky5000 on Fri Sep 04, 2009 11:35 am
09/03/09 update fans installed and working
making it a little bigger
Cutting on side of the mounts off to fit in the cutouts
Mounted using bolts to the existing holes
add my new fan grills(speaker covers) back on
still a nice clean look in the front
tested and works.
jj_sky5000
Aerogate Geek
Postby biggatomic on Fri Sep 04, 2009 12:10 pm
OH snap get your radio raheem on!!!!! i will be watching this thread close. LOVING THE WORK SO FAR :D :D :D :D :D
Corsair Obsidian 800D
Thor's Hammer
EVGA E759 CLASSIFIED LIMITED EDITION
Intel® Core™ i7 Processor 920
12 gigs DDR3-1600
Asus XONAR HDAV 1.3 Deluxe
(2) VELOCIRAPTOR (raid 0) & (4) 2TB WD Caviar
(2)gtx275 Arctic Cooling Accelero XTREME cooled
User avatar
biggatomic
CM Beta Tester
Postby Marcam923 on Fri Sep 04, 2009 12:37 pm
Very neat idea! Will be watching for more!! :bounce:
User avatar
Marcam923
CM Beta Tester
Postby mstjuan on Sat Sep 05, 2009 9:52 pm
perfect for the living room mate.
User avatar
mstjuan
Centurion Officer
Postby PaPang on Sat Sep 05, 2009 10:47 pm
Cool touch with the fans instead of the speakers, no cooling probs here, heheh!
Cheers and Saludos
User avatar
PaPang
Stacker Hacker
Postby jj_sky5000 on Mon Sep 07, 2009 10:07 am
06/05/09 & 06/06/09
Motherboard & mounts.
Need to make a few cuts and see if everything fits
looks good
now i am adding the the MFP51 multi-media lcd
Now for the Cooler Master enclosure
Just enough room :)
I am going to clean the edges with some rubber
Back of the case
cut a small window
jj_sky5000
Aerogate Geek
Postby PaPang on Mon Sep 07, 2009 10:11 am
A radiator! Boy that is cramming things in a lot! Oh, and it is fair to answer back (feedback) as this is not your regular modding type forum. Your comments and pearls of knowledge are appreciated!
Later
User avatar
PaPang
Stacker Hacker
Postby jj_sky5000 on Mon Sep 07, 2009 10:41 am
PaPang wrote:A radiator! Boy that is cramming things in a lot! Oh, and it is fair to answer back (feedback) as this is not your regular modding type forum. Your comments and pearls of knowledge are appreciated!
Later
there will be 2 " radiators Duel loop
jj_sky5000
Aerogate Geek
Next
Return to Modding & Overclocking
Who is online
Users browsing this forum: No registered users and 1 guest
