MORPHIUS -2009 Mod Contest Entry-finished BRODER
All about overclocking and modding techniques, how-to's and worklogs.
Moderator: CM Moderator
Postby Maciel C. Barreto on Sat Jul 25, 2009 9:49 pm
Hello to all
I thought of making a case to be a ROBOT that was well from WAR damaged, dirty and broken, after participating in some battles, but some parts were exposed and at the same time have a visual and dirty.
You will monitor Morphius category (UNIQUE)
HIPER Z600 CPU COOLER CM
REALPOWER M520 CM
FAN 120MM cooler master
Well I will now staff in modeling CLAY to details to get a way to work with fiber.
observed that the clay is taking shape and details, it greatly craft a casemod
values look like after you finished?
I will do now that part of the head, which is above a depth greater importance to have a good result in casemod
after you carve all the details of the model, it is already almost ready to do-take a form of silicone, to trabalahr with fiber.
Last edited by Maciel C. Barreto on Thu Oct 01, 2009 6:02 pm, edited 9 times in total.
User avatar
Maciel C. Barreto
Vortex Dreamer
Re: MORPHIUS by Maciel Barreto- Brazil-2009 Mod Contest Entry
Postby Maciel C. Barreto on Sat Jul 25, 2009 10:07 pm
New part, I show how this part was and how good to have enough detail to enhance the casemod so you may have and enjoy the maximum of imagination and appreciation for the very small details that count at the end.
placing of PVC to various legal details, the details are very nice.
I am now a cutting tip of aircraft to the tip of the fan
now completed in the details
User avatar
Maciel C. Barreto
Vortex Dreamer
Postby Icejon on Sun Jul 26, 2009 2:23 am
This will be an amazing mod I can feel it. Your clay modelling is fantastic!
Beta testing moderator - Have a Better Day Everyday
Strength, Security & Control
User avatar
Icejon
CM MKT
Postby Maciel C. Barreto on Sun Jul 26, 2009 4:08 am
here now a part of the waist and detailed but still waiting for the painting, that is good to concentrate to get a legal result, since independence the whole body will be arrested.
Now I'm doing the leg where did the details in PVC and fiberglass, and reinforced to handle the structure of the entire modding,
User avatar
Maciel C. Barreto
Vortex Dreamer
Postby Maciel C. Barreto on Sun Jul 26, 2009 4:23 am
ways is to play in CLAY silicone and then several layers of plaster to give support to the silicone that is booting, it is a simple but slow, with a wealth of detail that the piece is made with glass fiber.
here already with this layer of plaster to maintain at that time I'm removing the mass for the withdrawal form to produce parts that will be the structure of Morphius
User avatar
Maciel C. Barreto
Vortex Dreamer
Postby Maciel C. Barreto on Sun Jul 26, 2009 5:23 am
That part was pretty ready too, imagine how it will look like the rest of the case?
Let's go another part now, 'I hope you like it, because that casemod took much work, but worth every minute.
User avatar
Maciel C. Barreto
Vortex Dreamer
Postby Valdisnei on Sun Jul 26, 2009 9:07 am
Uhull!
One more case from brazil =D There we go! =D
Valdisnei
LED Head
Postby Maciel C. Barreto on Sun Jul 26, 2009 8:25 pm
I will now show as was the result of the entire sculpting CLAY and then in the form of silicone,
making glass fiber in the form and removal of semi finished parts. see how the structure was already in the casemod fiberglass.
Morphius the warrior who came from another galaxy is gaining shape and bold lines to each post, the visual look aggressive and a
good dose of Robot with legs of spider fell well in this project.
The lighting in my concept is another important factor to life in this project, so the amount of lighting I have a very good effect and a satisfactory result
User avatar
Maciel C. Barreto
Vortex Dreamer
Postby Maciel C. Barreto on Sun Jul 26, 2009 8:32 pm
so good to see the winning Morphius way, enough to be exciting, see it becoming real, leaving the role, gaining form accessories, life, but there we still have much to show, this wonderful project that it, is getting very beautiful and visually impressive. I have a special place you will see the COOL HYPER Z600 in central point of this project, which brings a visually enthralling.
User avatar
Maciel C. Barreto
Vortex Dreamer
Postby PaPang on Tue Jul 28, 2009 12:53 am
Muito Maravilhoso! Now this is an amazing scratch mod, that borders on the fantistic. Congrats Maciel, I have to admit your mod beats mine hands down.
Cheers,
Kick butt both ways: at the office and at home with Papang BizRigs!
Brought to you from Cancun, Mexico
User avatar
PaPang
Stacker Hacker
Postby Maciel C. Barreto on Tue Jul 28, 2009 5:19 am
I am grateful for the hope that in the last post of my casemod, you enjoy it very much because Morphius was one of the most beautiful cases that I created, by the end of the month you will see how it will stay, every detail that made a casemod Morphius icon
User avatar
Maciel C. Barreto
Vortex Dreamer
Postby Maciel C. Barreto on Tue Jul 28, 2009 8:01 pm
User avatar
Maciel C. Barreto
Vortex Dreamer
Postby Maciel C. Barreto on Tue Jul 28, 2009 8:03 pm
I question that part of being well set and tight it will support the entire body of Morphius, so the legs are solid to hold the weight of hardware, while maintaining stability and security.
User avatar
Maciel C. Barreto
Vortex Dreamer
Postby PaPang on Wed Jul 29, 2009 1:07 am
If your base is fiberglass reinforced (2 layers atleast) your threaded bar (3/8" or more??) should hold up fine as long as it is more or less balanced. I hope you applied fiberglass on both sides of the base, otherwise you outer washer will begin to eat into the clay. Three legs are not the stablest especially if you have a high center of gravity. I would suppose that your heaviest components will go in that base (power source, hard drive). Flex from the legs should not be a problem.
Cheers
User avatar
PaPang
Stacker Hacker
Postby Maciel C. Barreto on Wed Jul 29, 2009 2:14 am
in fact it is all done in glass fiber is the only clay modeling ways to do with fiber, and are four legs to support the entire body with 3 layers of fiberglass, but all hardware will be distributed in whole body , with the full balance casemod.
User avatar
Maciel C. Barreto
Vortex Dreamer
Next
Return to Modding & Overclocking
Who is online
Users browsing this forum: No registered users and 3 guests
cron
