In Greek the metal was known by the name chalkos (χαλκός). Copper was a very important resource for the Romans, Greeks and other ancient peoples. In Roman times, it became known as aes Cyprium (aes being the generic Latin term for copper alloys such as bronze and other metals, and Cyprium because so much of it was mined in Cyprus). From this, the phrase was simplified to cuprum, hence the English copper. Copper was associated with the goddess Aphrodite/Venus in mythology and alchemy, owing to its lustrous beauty, its ancient use in producing mirrors, and its association with Cyprus, which was sacred to the goddess. In astrology, alchemy the seven heavenly bodies known to the ancients were associated with seven metals also known in antiquity, and Venus was assigned to copper.
The Plan
Build the ultimate and most innovative Water Cooling system ever seen.
Over time I have seen all the components of a computer change periodically, since the introduction of the water cooling system has been poorly updated. So I decided to create my own Water Cooling System "CypriUm - The Ultimate Water Loop Case".
I'll use the same measures as a Full ATX Case and I'll follow the Water Cooling traditional parameters, using 1/2" copper pipes, radiator, reservoir, water blocks (CPU and GPU) and hoses, the difference will be the integration of these components with the design of the case.
Things that I want to accomplish:
- Custom Made Reservoir (Not like the Original Plan but better)
- Custom Water Loop (Done)
- Less Tubing – More AirFlow (Done)
- Less Cable (Done)
- Unique Shape (Done)
Sub-Mods
#1 PSU - Mod (Done)
#2 Graphic Card Mod (Done)
#3 SATA Sleeving (Done)
#4 120mm Case Fan Mod (Done)
#5 Custom Power Button (Done)
Cu = Copper = CypriUm
The Materials
- 1/2" Copper Pipes
- 1/2" Copper Ts
- 1/2" 45° Copper Elbows
- 1/2" 90° Copper Elbows
- 1/2" Acrylyc Tube (3)
- 1/2" Fittings (6)
- Double 120mm Radiator (1)
- Pump (1)
- CPU and GPU Water Block
- 6' of Hose
- Acrylic Sheet 30"x28 (2)
- Pipe Cutter
- Bernzomatic Propane
- Bernzomatic Welding Rods
- Clear Epoxy
- Fiberglass Resin and Hardener
- 140mm Case Fan (1)
- 120mm Case Fan (3)
- Bright Orange LEDs (16)
- Hex Mesh (2)
- Pennies (2)
video: http://www.youtube.com/watch?v=hCNXrMxSEPw
