Project: Mad-Oil by MstJuan - Mod Contest 2009 Completed
All about overclocking and modding techniques, how-to's and worklogs.
Moderator: CM Moderator
Postby mstjuan on Mon Jul 13, 2009 3:59 pm
HI everyone here i will be posting my work log for mad-oil project.
I shell be contesting under the Unique Category with my Mad-Oil.
The Idea i has always been in my dreams to make my own case and here as the first time trying i shell be trying to make something new.
I be using a fridge as the base for the case. here is a photo.
more details will come along as i do more work.
User avatar
mstjuan
Centurion Officer
Re: Project: Mad-Oil by MstJuan - Mod Contest 2009 Entry
Postby Dr Torchwood on Mon Jul 13, 2009 7:38 pm
Just a minor concern about your using a fridge as I tried to build a running system inside a running fridge myself circa 1997/98.
Fridges make great cases as far as sound proofing / vibration control.
But only when unplugged / not running as a fridge, only used as a case itself.
The problem when building inside a fridge that is running is CONDENSATION...
Hot parts in cooled air equals water droplets where you just don't want them.
I managed to fry what was back in the day quite a large sum of monies worth of parts.
I can't wait to see what your project ends up like, I am 100% intrigued by this one.
Lots of pictures please...
Asus M4A79 Deluxe
AMD Phenom II X4 Black Edition
CoolerMaster V10
8GB OCZ DDR2 PC2-8500 Platinum
Kingwin Mach 1 Modular 1200wt
Asus EAH4870X2 2GB DDR5
WD Velociraptor 300GB 10k
Win 7 Beta 64 bit
Razer Barracuda AC-1
LG GGW-H20L Blu-Ray
User avatar
Dr Torchwood
CM Moderator
Location: Beach resort area of Delaware on the East Coast USA.
Postby mstjuan on Mon Jul 13, 2009 7:53 pm
I will not be using the fridge Cooling system it will get slightly more complex.
User avatar
mstjuan
Centurion Officer
Postby Dr Torchwood on Mon Jul 13, 2009 8:17 pm
mstjuan wrote:I will not be using the fridge Cooling system it will get slightly more complex.
That's sweet to know...
Had me worried for a moment, as I said I made that mistake back in the day lol.
Can't wait to see what you create... kinda' have me on the edge of my seat waiting.
Asus M4A79 Deluxe
CoolerMaster V10
Win 7 Beta 64 bit
LG GGW-H20L Blu-Ray
User avatar
Dr Torchwood
CM Moderator
Postby PaPang on Tue Jul 14, 2009 1:21 am
Really odd mod! Hey, it even rhymes! Do not forget to list your 5 Cooler Master components to use in it. Very important.
Saludos y Suerte
Kick butt both ways: at the office and at home with Papang BizRigs!
Brought to you from Cancun, Mexico
User avatar
PaPang
Stacker Hacker
Postby mstjuan on Tue Jul 14, 2009 4:01 am
I will list them as soon as i but them so i know the component name. if i may ask why is odd?
Sorry for my English, But is not my native language.
MOst Pro i will need to use only a few fans and a cooler.
User avatar
mstjuan
Centurion Officer
Postby mstjuan on Tue Jul 14, 2009 4:43 am
Today i started Cutting parts of my case.
here are the photos.
Bottom Part of the fridge.
Top Part
User avatar
mstjuan
Centurion Officer
Postby mstjuan on Wed Jul 15, 2009 4:15 am
here are more photos.
today i stayed building the optical drive base which will hold the optical drive in place, The material Used is PVC sheet.
Here is how it fits..
And here is how the Optical Drive will fit. ( This drive i am using is just for measurements only.)
More to come i try and post a video i hope i manage.
User avatar
mstjuan
Centurion Officer
Re: Project: Mad-Oil by MstJuan - Mod Contest 2009 Entry Updated
Postby mstjuan on Fri Jul 17, 2009 6:39 am
Parts i will be using
1)Coolermaster HyperTX2 Universal CPU Cooler *1
2)120mm Coolermaster Internal RED LED Fan*2
3)92mm Coolermaster Internal Case Fan*2
This are the only local supplies, I could find.
User avatar
mstjuan
Centurion Officer
Postby mstjuan on Fri Jul 17, 2009 6:40 am
To day i started building the HD'S heat sinks which will fit into the fridge door.
I will continue on saturday
User avatar
mstjuan
Centurion Officer
Postby PaPang on Fri Jul 17, 2009 12:08 pm
If I´m not wrong, I would say your in!
Happy modding
User avatar
PaPang
Stacker Hacker
Postby mstjuan on Sat Jul 18, 2009 1:48 am
i hope is enought.
User avatar
mstjuan
Centurion Officer
Postby yAu on Sat Jul 18, 2009 4:23 am
that's good.......no worry here
can't wait to see your mod :bounce:
yAu
CM MKT
Postby mstjuan on Sun Jul 19, 2009 8:02 am
today i continued on the case . will post later on sunday...
User avatar
mstjuan
Centurion Officer
Postby mstjuan on Tue Jul 21, 2009 2:54 am
Progress on work:
The fridge door in here i will be housing the HD i will be using one or two i still don't know but the door takes two. I am also planing to install four fans two inflow of 80mm each and two out flow of 92mm each plus i also used two Alloy ( alumina and manganese ) heat sinks so to cool more the hard drive
Out side ( still a lot to do to make it nice).
Inside part with out the drive everything will be secured batter since for now i just fixed everything with hot glue to see the measurements.
Al so i have been working on the front part of the fridge it' self there will be the rest of the components.
I will be using white pvc to hold the perspex in between. at the bottom you will see a piece of plastic that represents the inner pvc that will act like a fails floor to make everything suspended.
Here i was thinking of making the main board and i just placed in place for measurement purposes only.
User avatar
mstjuan
Centurion Officer
Next
Return to Modding & Overclocking
Who is online
Users browsing this forum: MSN [Bot] and 2 guests
