Project Coolermaster HAF 932
All about overclocking and modding techniques, how-to's and worklogs.
Moderator: CM Moderator
Postby tantric on Thu Jul 09, 2009 11:19 am
Hello all! i just want to share my Coolermaster HAF 932 Case.
-the HAF 932 case arrives at my workshop.
- a quick view of the top panel fan
-the case was quickly disassembled and sent to the powdercoating shop.
tantric
Aerogate Geek
Re: Project Coolermaster HAF 932
Postby tantric on Thu Jul 09, 2009 11:22 am
while waiting for the chassis to be powdercoated, I decided to do some interior detailing.
-the 5.25 bay locks.
-also got some custom case feets for the case.
-silver looks a bit boring so decided to give it a little kick :o
also got some Artic Cooling RC memory coolers,
http://www.arctic-cooling.com/catalog/product_info.php?cPath=39_&mID=124
-and decided to paint it red, to match the color scheme :D
tantric
Aerogate Geek
The side panel mod.
the HAF's side panel design is a bit tricky to do. the embossed metal on the mesh part, combined with the thick secc steel used on the panel makes it a pain in the arse to cut.
- decided to leave the corners of the honey comb mesh, they will be used as mounting holes for the screws when attaching the acrylic side panel. this was the trickiest part :D
-cleaning up the edges using my trusty file.
-the finished panel. whew :o
tantric
Aerogate Geek
Postby tantric on Thu Jul 09, 2009 11:24 am
i painted the coolermaster logo with red candytone paint to match the overall case theme.
i also did the same, with the custom screws that will be used for the side panel acrylic.
tantric
Aerogate Geek
Postby tantric on Fri Jul 10, 2009 8:06 am
got myself some clean cut sleeves and decided to do the 24pin and 6pin PCIE extentions.
i also sleeved the fans that will be used on the swiftech MCR 320.
sleeved power reset and led indicators.
some more parts just arrived.
mcp pump 355 with an EK D5 X-top :D
tantric
Aerogate Geek
Postby tantric on Fri Jul 10, 2009 5:17 pm
made some custom led moduels using 5mm superbright leds :D
tantric
Aerogate Geek
Postby Dr Torchwood on Fri Jul 10, 2009 11:34 pm
Love the use of the super brights.
I managed to buy a strip of 48 superbright UV (black light) LEDs for use in my 830...
Amost everything in a 4 foot radius is affected by them even tho' the case is closed... when the one side is open OMG it is like being in a european nightclub lol.
Are you going to be adding switches or a controller for your custom LED arrays?
I am looking into a possibility to 'Dim' the other LEDs in my personal case & hook the dimmer to a photo sensor, I'd like to attain between 1/3rd & 1/2 brightness at night.
Have you looked into that sort of thing?
Asus M4A79 Deluxe
AMD Phenom II X4 Black Edition
CoolerMaster V10
8GB OCZ DDR2 PC2-8500 Platinum
Kingwin Mach 1 Modular 1200wt
Asus EAH4870X2 2GB DDR5
WD Velociraptor 300GB 10k
Win 7 Beta 64 bit
Razer Barracuda AC-1
LG GGW-H20L Blu-Ray
User avatar
Dr Torchwood
CM Moderator
Location: Beach resort area of Delaware on the East Coast USA.
Postby tantric on Sat Jul 11, 2009 7:48 am
lol!
anyway. about the leds i'm only placing around 3-4 sets of modules on this project. just enought to illuminate, certain parts of the case. i'm not sure if i'll be needing a dimmer for that. :D
but i've tried using an old fan controller to dim the leds. it's a quick fix if you do not have the spare time and parts to make a dimmer.
:cheers: :cheers: :cheers:
tantric
Aerogate Geek
Postby tantric on Mon Jul 13, 2009 7:16 am
just got the case back from the powdercoating shop.
the lasercut acrylic side panels also arrived.
closeup...
installed!
tantric
Aerogate Geek
Postby Dr Torchwood on Mon Jul 13, 2009 6:03 pm
Coming together beautifully...
Can I ask if your acrylic was cut local or did you have to send out quite a distance?
(Also what was the turn around on sending out, getting them back?)
They certainly did a great job with the acrylic & wouldn't mind somewhere capable of doing that in these parts.
(I'm at a beach resort area, not known for it's mix of powdercoaters & laser cutting companies :-( )
Keep the pics coming...
Asus M4A79 Deluxe
CoolerMaster V10
Win 7 Beta 64 bit
LG GGW-H20L Blu-Ray
User avatar
Dr Torchwood
CM Moderator
Postby PaPang on Thu Jul 23, 2009 2:21 am
Wow, nothing can beat a laser or water cut for sure! By the way, are you entering the 2009, Mod Contest? If you are, you just have to add "2009 Modding Contest Entry" or of the sort in the title to let us know.
Cheers
Kick butt both ways: at the office and at home with Papang BizRigs!
Brought to you from Cancun, Mexico
User avatar
PaPang
Stacker Hacker
Postby tantric on Thu Aug 20, 2009 12:51 pm
used to work at an advertising company, you'd be surprised that the tools/materials used in the business are very similar from what we use in modding.
some more updates. the custom top used on the D5 top looks kinda plain and boring
and it didn't really match the theme of the case. so decided to spice things up a bit.
started by dis assembling the pump.
then we proceeded to murdering the top. lol!
i'm using a 7/16" drill bit to enlarge the original hole.
then a G1/4 pipe tap.
tantric
Aerogate Geek
Postby tantric on Thu Aug 20, 2009 12:55 pm
then i used some left over lian-li side panels.
and cut it to size using a hand nibbler.
a quick spray of candy red spraypaint. and heres the end result.
tantric
Aerogate Geek
Postby zer09 on Fri Aug 21, 2009 2:23 pm
great accents! :)
zer09
LED Head
Postby doki on Fri Aug 21, 2009 4:19 pm
Very nice.... I love the color
doki
LED Head
Next
Return to Modding & Overclocking
Who is online
Users browsing this forum: No registered users and 2 guests
