PC Cable management clamps
http://www.mnpctech.com/CableClamp.html
Heres the front "Sniper" crosshair intake grill.
We've milled a hole on each side of the cross hair intake grill for a 5mm white led
Moderator: CM Moderator
Maxession wrote:And we'll be waiting on it.
If you plan to use sponsored components for you mod:
* All modding work must be done by you, not the sponsors.
* You cannot do any advertising for the sponsors or any product in your worklog (i.e. posting links to online ecommerce sites for the product).
PaPang wrote:Controversial, but the rule is clear, I agree. The project should go on but edit out the ads and direct links. Any reason to not do so?
Return to Modding & Overclocking
Users browsing this forum: Yahoo [Bot] and 2 guests
