Project: Mission - 2009 Mod Contest Entry - Completed
All about overclocking and modding techniques, how-to's and worklogs.
Moderator: CM Moderator
Postby slipperyskip on Sat Jul 04, 2009 9:33 am
Mission
A mission-style walnut side table built around a Cooler Master aluminum mid tower ATX case. The modified bottom-to-top cooling system and easily replaceable decorative panels help make Mission a cool-running spousal-friendly gaming/HTPC system. Features include a large replaceable inlet air filter, temperature-controlled exhaust fans and a self-contained “plug-in” chassis design.
Mission was built entirely by myself in 11 weeks with a minimal use of power tools. It was constructed in a "built-up" prototype modeling style and contains 366 individually cut pieces of walnut, maple, birch aircraft-grade plywood and basswood.
Mission-style is a type of furniture popular in the United States during the turn of the 20th century. It was inspired by the wood furniture of Spanish missions in California.
A sample of construction photos from the worklog:
Review of Mission specs...
Intel E7400 C2D
Gigabyte EP43-UD3L motherboard
Palit GeForce GTX 280
4GB Crucial DDR2 1066
Silverstone Nitrogon NT06 HSF
Silverstone 600W Strider PSU
Seagate 400GB HDD
Sony Blu-Ray optical drive
Cooler Master Mystique 631
Last edited by slipperyskip on Fri Oct 02, 2009 9:28 am, edited 20 times in total.
User avatar
slipperyskip
Vortex Dreamer
Re: Project: Mission
Postby slipperyskip on Mon Jul 06, 2009 10:00 am
Yanked the face plate off and threw it away.
Removed the front panel ports, feet and front fan.
Drilled out the pop rivets that secure the 3.5" internal drive rack and removed.
Taped over the back panel to protect it during the build. Removed the side panel latch and air duct to get a perfectly flat panel.
Installed some temporary waster pieces to provide spacing and support.
1/8" birch plywood being fitted and measured.
Panel cutting rig trimming up some plywood.
Test fitting top panel including corner glue blocks.
User avatar
slipperyskip
Vortex Dreamer
Postby biggatomic on Mon Jul 06, 2009 10:15 am
nice cant wait to see the finished product.
Corsair Obsidian 800D
Thor's Hammer
EVGA E759 CLASSIFIED LIMITED EDITION
Intel® Core™ i7 Processor 920
12 gigs DDR3-1600
Asus XONAR HDAV 1.3 Deluxe
(2) VELOCIRAPTOR (raid 0) & (4) 2TB WD Caviar
(2)gtx275 Arctic Cooling Accelero XTREME cooled
User avatar
biggatomic
CM Beta Tester
Postby yAu on Tue Jul 07, 2009 9:06 am
hi slipperyskip,
Code: Select all
You don't really mean "all" do you?
as long as you keep updating your mod progress here, then you are fine. I assume you'll be entering the contest under 'Mid Tower' category, then just the case alone would be enough for qualification.
looking good.......Good luck!! :cheers:
yAu
CM MKT
Postby slipperyskip on Tue Jul 07, 2009 9:35 am
yAu wrote:hi slipperyskip,
Code: Select all
OK. Thanks for clearing that up. Yes, it will be submitted in the Mid Tower category.
I do have equipment (non-Cooler Master) that is going inside but I was curious (cautious?) about how to post that info. Some of it has been donated. Any good words?
User avatar
slipperyskip
Vortex Dreamer
Postby slipperyskip on Tue Jul 07, 2009 1:05 pm
biggatomic wrote:nice cant wait to see the finished product.
Thanks. It might turn out good. :lol: We'll see.
Gluing up some stock.
Set to dry while pinched between my straightedge and a piece of laser-cut basswood.
Sub-sections being glued together at right angles. I'm using small square blocks to keep the angle true during clamping.
The case is over on its back to do a test fitting.
The bottom panel will have a 2 x 120 radiator grill installed (eventually).
The cross members are still all temporary spacers.
Thanks for looking.
User avatar
slipperyskip
Vortex Dreamer
Re: Project: Mission - 2009 Mod Contest Entry
Postby yAu on Wed Jul 08, 2009 1:23 am
Code: Select all
since the case alone will meet the qualification requirements, you are free to list any components you are using. Forum members would be voting for the winners so what matters should be the end-result, not what components you have. :mrgreen:
yAu
CM MKT
Postby PaPang on Thu Jul 09, 2009 1:22 am
Wow, wood! Good to set an example in favor of the ecology and use of renewable resources. I've admired other wood working modder-artists & I expect, with your mod, to add another to the list. Best of Luck!
Kick butt both ways: at the office and at home with Papang BizRigs!
Brought to you from Cancun, Mexico
User avatar
PaPang
Stacker Hacker
Postby slipperyskip on Sun Jul 12, 2009 12:04 pm
Vent openings for the top and bottom panels are measured and drawn out. The left panel cutout has been "power scored" with a Dremel cutout wheel. The back of the panel is also penciled in and scored. I do this because plywood is notorious for surface chipping caused by saw blades and drills. I like sharp clean edges.
Those are excess pencil marks not over-cuts. The scoring is a perfect rectangle.
The drill bit used for the pilot holes caused the predicted damage but notice it didn't travel beyond the score marks.
A power tool! I broke down and bought the cheapest jigsaw available. I hate using them but they do save time for larger projects like this one.
Of course I can't use a power tool like a normal person does. I don't make any attempt to cut along the line. Instead I leave a small amount of material that I will later hand rasp and rough sand down to the measurement line.
Ta-da!
The jigsaw ripped up the plywood surface but the damage remained within the scored boundary.
Two identical panels with rough-cut openings. The top panel will hide two 120mm exhaust fans but look like it might be a 3 x 120. I have decided that the bottom panel will be an open vent with filters instead of fans. Both openings will have identical mesh covers with thin wooden frames.
After a couple of hours of relaxing rasping, filing and sanding I get these.
Thanks for looking.
User avatar
slipperyskip
Vortex Dreamer
Postby Dr Torchwood on Sun Jul 12, 2009 10:33 pm
I am really enjoying your project.
It is great as another member said to see more wood being used.
I really admire the fact that you prefer to had 'rasp' & use other traditional yet time consuming methods in the production of your pieces.
I hope that when people look at the finished product that they also take into account the methods of production, appreciate the time it takes to 'hand finish' as you have been doing.
Scoring with the dremel is a great tip that you have shared with the others too, way too many projects have been 'messed up' by not pre-scoring materials & I hope that future modders have taken note.
My question is why you chose to go with a 'Ply' rather than a solid sheet?
Was it more cost effective or have you found that Plywood has certain properties that 'solid' sheets of the same finish doesn't have when it comes to case modding?
My own attempts at wooden cases in the past have suffered 'warping' due to heat, both laptop & full sized towers.
(more laptop tho' which warped all over, the tower warped on top & rear only)
For those I had used thin solid sheets & not ply... hence my question about about having found certin properties in the ply, such as is it more heat resilient (sp?).
Great pictures & fantastic to see your work.
Can't wait to see more as the project progresses.
Dr. T
Asus M4A79 Deluxe
AMD Phenom II X4 Black Edition
CoolerMaster V10
8GB OCZ DDR2 PC2-8500 Platinum
Kingwin Mach 1 Modular 1200wt
Asus EAH4870X2 2GB DDR5
WD Velociraptor 300GB 10k
Win 7 Beta 64 bit
Razer Barracuda AC-1
LG GGW-H20L Blu-Ray
User avatar
Dr Torchwood
CM Moderator
Location: Beach resort area of Delaware on the East Coast USA.
Postby slipperyskip on Sun Jul 12, 2009 11:29 pm
Dr Torchwood wrote:I am really enjoying your project.
Dr. T
Thank you for your comments.
Plywood and other engineered wood products such particle board and MDF seem to have a reputation for poor quality when in fact they are far superior to "solid sheets" when it comes to stability. The fact that they do this with mostly recycled waste material makes it even more impressive but I suspect this is also the origin of the prejudice.
Applying thin veneers of exotic woods over a strong stabile structure just makes sense to me. I have had good luck with this method and it is easy on my environmental conscience.
For my smaller projects such as Ingraham and Pico Bayard I use an aircraft grade Finnish birch plywood that is several levels above the standard fare I'm using here. The difference was that Lowes was open on the 4th of July and my supplier wasn't. LOL
For the record I am not a woodworker or carpenter of any kind. I have several friends who are master cabinetmakers. I have learned a lot from them but they mostly just laugh at many of my methods. :D
User avatar
slipperyskip
Vortex Dreamer
Postby slipperyskip on Mon Jul 13, 2009 8:23 pm
I'm using a motorcycle bungie cord to hold in all four corners while I glue things up.
Breaking out the big boy clamps for this one.
I'm keeping the project elevated until it can support its own weight. I like to break out my old vintage 1941 straightedge now and then.
Scaffolding. I like to think this part of the build is somewhat like building a Roman arch. Everything is unstable and delicate until you drive in that keystone. Large chance for major fail here.
A small, thin spacer being glued up over the edge of the top plywood panel. I'm showing this because getting wood glue on the wrong surface can be a huge problem here. I applied a piece of Scotch tape across the underlying waster piece to protect it from any glue excess.
Clamping scheme for a leg support.
A 1/2" square board starts to fill in the leg and locks the plywood panels into the structure. The legs will eventually be built up until they are 1 3/8" square.
I started work on the optical drive bezel. Measured the opening and scored it with an X-acto knife. Tore out a bunch of the material by drilling a series of holes. Took it closer to the lines with my round wood file. I'll take it the rest of the way with some 60 grit sandpaper wrapped around a sanding block.
The back of the DVD bezel showing where I glued up a thin spacer.
Thanks for looking.
User avatar
slipperyskip
Vortex Dreamer
Postby Icejon on Tue Jul 14, 2009 2:17 am
This is looking very good. I like the use of wood on an otherwise lightweight chassis.
Beta testing moderator - Have a Better Day Everyday
Strength, Security & Control
User avatar
Icejon
CM MKT
Postby slipperyskip on Wed Jul 15, 2009 6:36 am
Clampage for segments of the rear legs.
DVD bezel dry fit. Again, a lot of the cross member wood in this photo is temporary.
I need to do some factory work. Here I'm lining up all four side rails to be measured at the same time. Consistency wiil keep help keep things square.
Cut some spacers.
Dry fitting some spacers.
Gluing operation. Keeping everything square.
Result of the first stage.
My micro-miter box setup that I use to cut spacers.
Sixteen more spacers for stage two.
This is not a solid block of wood. I loosely assembled all sixteen spacers together and sanded each end down until they were all even.
More gluing.
Result of stage two.
Finally some assembly. Here I have pulled back the the bottom bracket to show how stuff interlocks.
The top bracket is ser into position.
Both brackets being dry fit.
Finally, all three center strips set into place for a test fitting and photo op.
Thanks for looking.
User avatar
slipperyskip
Vortex Dreamer
Postby PaPang on Wed Jul 15, 2009 12:08 pm
I must be breathing fiberglass resin fumes cuz my head is spinning! I guess you are going to surprise us all at the end as you are now.
Great work and detail
User avatar
PaPang
Stacker Hacker
Next
Return to Modding & Overclocking
Who is online
Users browsing this forum: No registered users and 2 guests
