so here's what the cooler monster looks like
i'll start in reverse order of the mods...
the lcd panel..
here's how its started
i stripped the panel out of its shell...
then extended a few cables to make sure nothing gets pulled off
then case the pcb behind the lcd to prevent any short circuit and laced the lcs in place of 2 drive bays
since it was a 6" wide lcd the fit was perfect..
and here's what it looks like at night
now the insides
i changed the led's on the front and added a few on the side fan to match the color of aquagate max...
a better look of the inside
added some green uv paint on the top and some blue on the bottom hard drive bracket just for experimentation
and here's a final pic of what it looks like in the end
