CM 690 case mod (09 modding contest entry)
All about overclocking and modding techniques, how-to's and worklogs.
Moderator: CM Moderator
Postby sirheck on Fri Jul 03, 2009 7:43 am
I have had this case for about a year or so.
Here are some of the stages of modding i have put it thru.
Its pretty basic and plain, but i will try to spice it up more for the modding contest.
SYS specs....
CM 690 case.
Q66 cpu
Asus Rampage X-48
Old= 8800GTX
New is 4770,s in CF.
This was with a single PA120.3 radiator, external.
http://forum.xcpus.com/members/sirheck- ... e-002.html
http://forum.xcpus.com/members/sirheck- ... e-006.html
http://forum.xcpus.com/members/sirheck- ... -1773.html
http://forum.xcpus.com/members/sirheck- ... 9-005.html
http://forum.xcpus.com/members/sirheck- ... -1905.html
http://forum.xcpus.com/members/sirheck- ... -1798.html
Same case but with a top mounted 220 radiator and no PA120.3 off the back.
And with an additional 220 radiator in the front.
Will try to clean it up a bit and change a few things here and there as well.
Reason: Mod Contest 09
sirheck
LED Head
Re: CM 690 case mod.
Postby PaPang on Wed Jul 22, 2009 5:52 am
Hey, you have a pretty slick setup. You should give your case some more bling and enter the Modding Contest. It could use more contestants and who knows, you might win something, besides getting additional acclaim for your rig. Just a suggestion.
Cheers
Kick butt both ways: at the office and at home with Papang BizRigs!
Brought to you from Cancun, Mexico
User avatar
PaPang
Stacker Hacker
Postby sirheck on Wed Jul 22, 2009 6:29 am
Thanks...have done a little changing to it since then.
Currently trying a theory i had for a mutant Phase water set-up.
Doesn't get me much more than ambients though. :cry:
sirheck
LED Head
Postby PaPang on Thu Jul 23, 2009 12:15 am
Great again! Seriously, you ought to give it some thought about entering the contest. You just have to have a better worklog (to prove you did it ) a more detailed photos of your work to show what innovations you're doing. And of course, like I mentioned, some bling to your case. Come on sirheck, don't be so modest!
Cheers
User avatar
PaPang
Stacker Hacker
Postby nicky_82uk on Fri Sep 04, 2009 4:36 am
PaPang wrote:Great again! Seriously, you ought to give it some thought about entering the contest. You just have to have a better worklog (to prove you did it ) a more detailed photos of your work to show what innovations you're doing. And of course, like I mentioned, some bling to your case. Come on sirheck, don't be so modest!
Cheers
yea i think so to we really could do with a better worklog all i see is pictures of a computer come on dont run away its pritty easy todo we dont beat you know
User avatar
nicky_82uk
Praetorian Soldier
Postby sunnyXtremist on Fri Sep 04, 2009 9:50 am
Cheers
Cheers
I agree with both Papang and nicky_82uk,
but you have a whole lot of plans in your mind, keep it rolling and it will be a success, we all learn as a modder by trial and test!!!
More power bro!
sunnyXtremist
Praetorian Soldier
Re: CM 690 case mod (09 modding contest entry)
Postby mstjuan on Sat Sep 05, 2009 9:49 pm
with your mod you getting me for a next project which i will call air ballon.
User avatar
mstjuan
Centurion Officer
Postby sunnyXtremist on Thu Oct 01, 2009 7:20 am
GOOD LUCK TO YOU AND TO ALL CONTESTANT, IT WAS GREAT TO KNOW YOU
sunnyXtremist
Praetorian Soldier
Return to Modding & Overclocking
Who is online
Users browsing this forum: MSN [Bot], Yahoo [Bot] and 2 guests
