THE INCREDIBLE HULK
http://modcontest2012.coolermaster.com/
Moderator: CM Moderator
THE INCREDIBLE HULK
Postby HULK on Sat Aug 11, 2012 6:29 am
[attachment=0]phpiYQ5OnAM.jpg[/attachment
My sctrach build will consist of the Avengers but THE HULK will be the main focus.
THE HULK
HULK
Aerogate Geek
Re: THE INCREDIBLE HULK
Postby HULK on Mon Aug 13, 2012 12:02 pm
I will be starting with my video card casing. The video card casing will be modded from the ground up. I think I will be the first who ever thought of case modding the video cards. If anybody knows of anybody else please let me know. I will be modding three video card casings, I will utilizing three way SLI.
This is my home made heat strip for bending my fiber glass.
To be continued.....
HULK
Aerogate Geek
Postby HULK on Tue Aug 14, 2012 5:24 pm
Now this is just one of the three I would have to mod.
The other two would be identical except the wording, one would have the word "THE"
and the other would have the word "INCREDIBLE"
HULK
Aerogate Geek
Postby HULK on Wed Aug 15, 2012 3:07 pm
This is how the other two video cards will look like
Now I'm going to build the base where the motherboard, Hard drives and SSD's will be placed.
The base will be suspended over the head of the HULK figurines, so there will be pictures
of the base showing one corner of the base open ended. So that a straight steel beam will be
place in that open to betray the HULK lifting the base.
This is the opening for the steel beam.
HULK
Aerogate Geek
Postby pcjunkie209 on Sat Aug 18, 2012 8:32 pm
This looks interesting. keep up the good work! :)
'I would rather be gaming" grunts-clan.com
http://pcjunkiemods.com
User avatar
pcjunkie209
CM Beta Tester
Postby Tortured_soul on Sun Aug 19, 2012 6:12 am
very nice work :)
wait for updates
User avatar
Tortured_soul
Vortex Dreamer
Postby frozensnail on Sun Aug 19, 2012 12:42 pm
Love the acrylic work, a passion of mine too, can't wait to see the finished results, n1 :D
frozensnail
Praetorian Soldier
Postby HULK on Sun Aug 19, 2012 6:11 pm
Thank You for the comments.
Now I'm going to continue with the base of the case.
This is the steel pole that will be used to hold the base above the hulks head.
Now this is the stand offs for the motherboard.
Half the base will have a lid that will be opened or closed.
The other half will be opened space where the video cards will be placed.
HULK
Aerogate Geek
Postby HULK on Tue Aug 21, 2012 5:33 pm
Now I will build one of the sides of the lid. It will have the holes for two 80mm fans.
This is the end face of the lid, where the clamping mechanism will be placed in order to keep lid attached to the base
HULK
Aerogate Geek
Postby HULK on Sun Aug 26, 2012 4:29 pm
Now the motherboard I will be using is the ASUS Rampage III Extreme.
In the next few photos i'm going to use the power and reset buttons on the motherboard to
power on my case mod. So I'm going to build a cover to protect from touching any other components.
on the motherboard.
Now the case modded video cards will have to be positioned differently, because since they where
modded with a 1/4" thick fiberglass and i'm going tri-sli. They will not fit on the motherboard.
So I decided to place the cards above the motherboard, above the base lid and I will be using PCI
express extenders in order to accomplish this. In the next few photos I will be building the brackets
that will hold the cards.
HULK
Aerogate Geek
Postby HULK on Sun Aug 26, 2012 4:45 pm
Oh yea I will be using three MSI GTX 480 video cards.
HULK
Aerogate Geek
Postby HULK on Sun Aug 26, 2012 4:54 pm
HULK
Aerogate Geek
Postby HULK on Mon Sep 03, 2012 10:28 am
This is how the case is looking, half the case will have a lid to cover half of the motherboard and the other half will expose the video cards. The covering lid can be lifted up.
Now I will be covering the face of the plexi glass with green glitter and clear polyester resin , in order to cover up the wires that will be seen through
the plexi glass.
After building the case with all the metal, plexi-glass, three video cards, motherboard, ssd's, and two hard drives.
The case got pretty heavy. So I had to think of a way to prop the case as shown in the photos, betraying the hulk lifting the case.
So I decided to build a base underneath. This base will include a 15TB home built server, it will include nine 3TB hard drives.
a motherboard and a power supply. The base will also include two UPS. Now this base will give me enough weight in oder to keep the
case from tilting over.
HULK
Aerogate Geek
Postby tnecniv102 on Wed Sep 05, 2012 6:24 pm
nice work..... i wish i have those tools too.. hehe
are you gonna use PCIE riser for your Graphic Cards??
if yes - its not advisable to use riser on high-end/power Graphic Cards.. or test it first..
User avatar
tnecniv102
Aerogate Geek
Postby HULK on Thu Sep 06, 2012 7:49 am
Yes, I will be using PCI express riser cards. I already tested and everything works OK. No problems.
HULK
Aerogate Geek
Next
Return to 2012 Mod Competition
Who is online
Users browsing this forum: No registered users and 1 guest
