CM 690
All about Chassis, Side Panel.
Moderator: CM Moderator
Postby tonschk on Fri Oct 19, 2007 10:05 pm
Richie wrote:Hey guys
Richie from down under here
Just got this case the other day and its pretty cool.
I also had a problem with the Hard Drive cage. i had to feed the sata cables through the back of the case making the cables tight
if theres another way please let me know. HD is all SATA.
Another thing about the power supply placement. The fan of the power suppy should be facing the motherboard or should it be facing the side of the case so it sucks air from the outside thanks guys
I think the PSU powersupply must be upside down ,suking air from the outside of the case ,there are plenty of holes at the bottom of the case
User avatar
tonschk
Praetorian Soldier
Postby knud on Fri Oct 19, 2007 10:49 pm
Psu should be faced downwards and sucking the cold air in from the bottom/outside
CM Parts shop
QX6850 @ 3.2 Ghz | Abit IP35pro | OCZ DDR2-800 4gb Reaper | Leadtek 8800GTX | WD Raptor 74GB | ATCS 840 | CM Real Power M700 | 1x CM Aerogate 3 | Z600 Black
User avatar
knud
Cooler than Cooler Master!
Postby -=Draven=- on Sat Oct 20, 2007 11:12 pm
knud // elessar wrote:Psu should be faced downwards and sucking the cold air in from the bottom/outside
The fan on the bottom of a PSU sucks or blows air?
Heh-heh alllriiight.
User avatar
-=Draven=-
Stacker Hacker
Postby Maxession on Sun Oct 21, 2007 12:14 am
It sucks air from in the case and the air goes out by the back again.
Parts shop N-America & Europe | CSX Shop | CM Storm | 2009 Mod Contest
ASUS P5Q-E ~ Intel C2DE8400 @ +4Ghz ~ CM V8 ~ Gigabyte 4850 ~ 2GB Adata 1066Mhz ~ CM M850W ~
CM Cosmos ~ Seagate 500GB ~ Samsung DVD & DVD-RW ~ iiyama 26"TFT ~ Dell 15"TFT
User avatar
Maxession
CM Moderator
Postby LuckyNV on Sun Oct 21, 2007 5:24 am
afaik ALL PSUs suck air into the unit and expells out the back
LuckyNV
Aerogate Geek
Does the 690 have a speaker?
Postby Karl_in_Chicago on Sun Oct 21, 2007 7:17 am
I didn't see a speaker lead or speaker itself but I admit I didn't totally disassemble the case.
I'm asking because I just finished assembling a new build and it's not coming up . . . but since Asus has their 3pin mobo LED lead I can't get any (limited) debug out of that and also don't have a speaker going for me.
Figured I'd ask, is there a speaker and, if so, where's the lead/what's it look like? Thanks.
Karl_in_Chicago
LED Head
Postby Paul343 on Mon Oct 22, 2007 7:40 am
Sorry, no speaker.
Paul343
Aerogate Geek
Postby Richie on Mon Oct 22, 2007 8:54 am
cool. thats how i installed it
Fan facing the bottem and sucking air from outside the case. i guess thats one of the reasons why they included rubber legs on the case.
Cheers guys
Richie
LED Head
I/O Function Panel Installation issues
Postby billyo55 on Wed Oct 31, 2007 8:37 am
I am in the process of my first pc build. I am having difficulty connecting the CM690 panel wires to my mobo(Asus P5N32-E SLI Plus). I connected the HDD LED, POWER SW, and RESET SW. How do you figure out what wires to plug into the the top panel of pins for the SPEAKER? Also, can you please tell me how I should go about connecting the PLED? The CM690 doesn't have the same pin configuration as the ASUS PLED. The CM690 has the wires configured +PLED,-PLED and my ASUS mobo has +PLED,SPACE,-PLED. Also, how do I connect the AC'97 and the AZALIA plugs?If you could help that would be awesome. I haven't had any luck with the CM phone reps.
billyo55
LED Head
Postby knud on Wed Oct 31, 2007 3:38 pm
The hdd led is indeed 2 pin fixed. The best way is to cut the connector in half and then connect it.
The AC'97 plugs go on the motherboard and there is only one way of fitting them in. (pls see the motherboard manual for the location of the audio header)
CM Parts shop
User avatar
knud
improvements
Postby tonschk on Wed Oct 31, 2007 5:41 pm
Hi , can somebody tell me please how often Coolermaster make revisions (improvements ) of their cases models , for instance Antec have already done two or three revisions of the old P180 model with the P182 ,P190 etc etc , thank you
User avatar
tonschk
Praetorian Soldier
Postby Fireheart on Thu Nov 01, 2007 2:59 am
I'd say revisions are made 'as needed'. It's too bad Antec needed to make revisions of that case.
Be Well!
Fireheart
User avatar
Fireheart
Praetorian Soldier
Postby sararocs on Thu Nov 01, 2007 9:44 am
If anyone has 6 or 7 case fans going, which ones do you have as exhaust and which ones as intake? Just curious as to the best combination for max ventilation.
sararocs
Aerogate Geek
Postby tonschk on Fri Nov 02, 2007 4:02 am
The Computer CASE can be compared with a wind tunnel , and I think we must do our best to keep the AirFlow in ONLY one direction (usually horizontal flow front to back ) and avoid turbulence, this Coolermaster CM690 also form a vertical AirFlow ( bottom to top ) , I am not a expert , but I think this Two AirFlows mix together end go toward the top and rear exhaust fans .I plan to buy this CM690 but I dont want to use the lateral side fans 120/140mm options , because this extra intake transversal AirFlow can induce turbulence and decrease the speed of the vertical and horizontal AirFlow (the small 80mm fan at the back of the MOBO is no problem because is exhaust),
User avatar
tonschk
Praetorian Soldier
Postby sararocs on Mon Nov 05, 2007 12:02 am
You have AC'97 and the AZALIA plugs, but with a GA-p35-ds3l mobo you can only plug in one or the other. Which should get plugged in A97 or Azalia? :?
sararocs
Aerogate Geek
PreviousNext
Return to Chassis
Who is online
Users browsing this forum: Google [Bot], MSN [Bot] and 1 guest
