ATC-220C-AX1
All about Chassis, Side Panel.
Moderator: CM Moderator
ATC-220C-AX1
Postby nikita on Mon Oct 30, 2006 3:27 am
Hey Guys
My Chassis has no more light on the front door (blue ATC)
Befor it was neon.. now there's no more light...
--> ATC-220C-AX1
What can I do?
nikita
Aerogate Geek
Postby [DP]Atomicpunk on Mon Oct 30, 2006 4:51 am
Could you explain in further detail
User avatar
[DP]Atomicpunk
Aerogate Geek
Postby Harib0 on Mon Oct 30, 2006 5:00 am
The LEDS that light up the ATCS image on the door have probably burnt out, so you will need to replace them
Harib0
Centurion Officer
Postby nikita on Mon Oct 30, 2006 7:47 am
How can I replace them?
I'm such a noob! :roll:
You have some documents or pictures for it?
Where can I buy these LEDS?
nikita
Aerogate Geek
Postby knud on Mon Oct 30, 2006 9:51 am
CM parts shop
You can request things, using the "contact us" form
CM Parts shop
QX6850 @ 3.2 Ghz | Abit IP35pro | OCZ DDR2-800 4gb Reaper | Leadtek 8800GTX | WD Raptor 74GB | ATCS 840 | CM Real Power M700 | 1x CM Aerogate 3 | Z600 Black
User avatar
knud
Cooler than Cooler Master!
Postby nikita on Mon Oct 30, 2006 11:56 am
Ain't there another possibility?
Why is the LED-Cable connected to a black box on right side of the cassy (front view)? What is the function?
nikita
Aerogate Geek
Postby nikita on Mon Oct 30, 2006 11:57 am
sorry, I mean chassis... 8)
nikita
Aerogate Geek
Postby Harib0 on Mon Oct 30, 2006 1:56 pm
nikita wrote:Ain't there another possibility?
Possibly and inverter like cold cathodes have?
It's easy to change leds have a look here: http://www.virtual-hideout.net/guides/c ... ndex.shtml
Harib0
Centurion Officer
Postby nikita on Tue Oct 31, 2006 12:22 am
Thanx for the link!
I saw, it's not a LED on the front door, it's a cathode
--> http://shop.wiltec.info/tabshop_s/kaltl ... _blau.html
I tried to take them out.. No chance on the first try.. Probably I have to take out a lot of items of the chassy for this cathode :evil:
I hope you understand what I mean... :roll:
Is there no documentation of the chassy??..
nikita
Aerogate Geek
Postby nikita on Tue Oct 31, 2006 5:42 am
Where can I buy (Europe) such a cathode?
It have to be a very slim one.. (like cable)
nikita
Aerogate Geek
Postby Harib0 on Tue Oct 31, 2006 6:30 am
CM Shop
If it's not listed on there (i don't think it is - send them a email request
Harib0
Centurion Officer
Postby nikita on Tue Oct 31, 2006 6:44 am
What do you think, if I buy a normal cold-cathod blue 100 mm (whit inverter), does it fit? (diameter ~10 mm)
nikita
Aerogate Geek
Postby knud on Tue Oct 31, 2006 11:33 am
I've got plenty CCFL's and I measered them for you, and they are max 10 mm (1cm) in diameter. So you're fine! :D
CM Parts shop
User avatar
knud
Postby nikita on Tue Oct 31, 2006 11:06 pm
Oh, wonderful! So I'll try to remove the inverter with Cold-Cathode and buy a new one in a store.
Thanx for your help and greetings from Switzerland! :D
nikita
Aerogate Geek
Postby knud on Wed Nov 01, 2006 3:52 am
No problem!
Let us know (and perhaps a picture) how it turned out, ok?
CM Parts shop
User avatar
knud
Next
Return to CASE
Who is online
Users browsing this forum: Google [Bot] and 5 guests
