Confused about SPEAKER, POWER_SW, H.H.D LED Connectors
All about Chassis, Side Panel.
Moderator: CM Moderator
Postby alnazli on Sat Apr 11, 2009 2:57 pm
i am currently building my system with Cosmos S
but i am not sure about the polarity these connectors:
SPEAKER Connector; Red wire is power, and Black wire is the ground?
POWER_SW Connector which is the poweron botton i think; Red wire is power, and Black is the ground?
H.H.D LED Connector which is the hardisk activity connector i think; Red wire is positive, and white wire is negative?
thank you
alnazli
Aerogate Geek
Re: Confused about SPEAKER, POWER_SW, H.H.D LED Connectors
Postby alnazli on Sat Apr 11, 2009 10:44 pm
a picture is better; please can you help me on this? i hope i am connectig them correctly
i think i got the POWER_SW connector reversed?
what about the speaker connector, and H.H.D activity connector?
Thank you
alnazli
Aerogate Geek
Postby alnazli on Sun Apr 12, 2009 12:55 am
anyone?
alnazli
Aerogate Geek
Postby EsaT on Sun Apr 12, 2009 7:13 am
Switches don't give damn about polarity and with indicator LEDs cathode pin (minus) is generally the common colour you find from from cables of both LEDs.
"The power of accurate observation is commonly called cynicism by those who have not got it."
-George Bernard Shaw
EsaT
Stacker Hacker
Postby pcew on Sun Apr 12, 2009 8:09 pm
This should help.
Note: Power Switch and Reset switch has no positive (+) or negative (-) so that means it should work anyway you connect on your motherboard. Now with HDD and Power Led you need to connect (+) with (+) on motherboard and (-) with (-). Simply connect Hdd Led and Power Led on to your board and turn on your computer if you don't see power led or hdd led just reverse the connectors. Simple.
Windows 7 base score : 7.4
pcew
Vortex Dreamer
Postby EsaT on Sun Apr 12, 2009 10:36 pm
Correct that attached graph. LEDs aren't any zeners which are used in reverse direction.
EsaT
Stacker Hacker
Postby neverXmiss on Mon Apr 13, 2009 8:40 am
On the connector itself you will see either a triangle or a G, triangle = positive and G = negative. On switches like the POWER SW and the RESET SW its not an issue, but you do have to get it right on the Power LED and HD Led.
CPU: Intel Core i7 920 @ stock
CPU Cooler: CM V8
Motherboard: Asus P6T Deluxe
GPU: MSI Geforce GTX 260 SLI
RAM: Corsair XMS 3 GB Triple Channel + Crucial Ballistix 3GB
PSU: CM Silent Pro 700W
Case: Storm Sniper Black Edition
NA Division Live Chat
User avatar
neverXmiss
CMUSA Customer Support
Return to CASE
Who is online
Users browsing this forum: Google [Bot] and 2 guests
