MY GEAR (HAF932 CASE MOD)
Showcase your mods for the world to see! http://www.coolermaster.com/casemod2011
Postby rikuntyudady on Tue Apr 26, 2011 8:36 pm
This is the most favorite PC case for me.
It made it to customizing that did not destroy as original a design as possible.
I'm sorry when wrong because I'm Japanese, and it is not good at English.
It ditches it to the reception desk part with an acrylic cutter.
"EL Wire" is installed according to the ditch.
The power supply is supplied from fan controller with fan connector.
It was lit.
It emits light uniformly.
The mesh part in the reception desk is painted on the orange.
"Knight flasher" is introduced into 5.25-inch bay.
This LED can choose the illumination pattern of the number of patterns including the reciprocation work right and left.
http://www.youtube.com/watch?v=c_sdz9-qxsQ
The mesh part of the bay cover is detached, and the acrylic piece of the smoke-color is installed.
The film label that prints the logo on an acrylic piece of the transparency is put on the other side.
The logo comes to the surface when shone on from the other side with LED.
The I/O panel part in the reception desk is customised.
Tape LED and the acrylic piece are used also for the other side here.
It becomes it like this when lighting.
The power supply of fan controller who is controlling the power supply of the illumination is turned on and can be turned off with this touch switch.
It lights by only the illumination whose fan controller's switch is turning on touching this switch.
http://www.youtube.com/watch?v=th69VJAnMRQ
The logo in the lock part in 5.25-inch bay is painted.
When the emery paper is put after the whole is painted in white, paints remain only in the logo part.
The base in the lock part is painted on the orange.
The HDD mounter is similarly processed.
It installed it.
The PCI cover is painted on the orange.
The side panel is made with the acrylic bord.
The acrylic bord is stopped by installing the board of the metal in the center, and using the hinge for here.
It is possible to open by this like the door.
LED of the memory cooler is exchanged, and the main body is painted.
The black one is sold now.
State of lighting.
The acrylic piece that prints the film label is installed in the hole for wiring in the upper part of the mother board.
Customizing of reception desk fan cover.
Because the side panel was made an acrylic bord, the back side of 5.25-inch bay is concealed.
It used "3M DI-NOC Carbon"
It's done.
Thanks. :)
YouTube
http://www.youtube.com/watch?v=18PSDBTEe4M
【Extra】
Tape LED is installed along an acrylic window of the side panel of normality.
When the label that prints the logo is pasted or the character is written with a fluorescent marker …
It is possible to make a hand-written character come to the surface.
PC gallery of the friends of Japan and mine is here.
And my blog is here. http://rikuntyudady.blog101.fc2.com/
User avatar
rikuntyudady
Vortex Dreamer
Re: MY GEAR (HAF932 CASE MOD)
Postby PaPang on Tue May 24, 2011 10:38 am
Ok! One of the few mods I have seen from Japan, kudos for registering & showing your wares! Very respectable build with a lot of fine details, and yes, the HAF is a fine case, I have one too but is still boxed because I am still figuring out what to do with it (going on 2 years so I admit I still don't know what to do, hehe). I lean more to scratch builds but I definitely have to do something with mine.
Best of Luck!
Cheers and Saludos
Kick butt both ways: at the office and at home with Papang BizRigs!
Brought to you from Cancun, Mexico by http://www.modding.com.mx!
User avatar
PaPang
Stacker Hacker
Postby rikuntyudady on Wed May 25, 2011 2:56 am
PaPang wrote:Ok! One of the few mods I have seen from Japan, kudos for registering & showing your wares! Very respectable build with a lot of fine details, and yes, the HAF is a fine case, I have one too but is still boxed because I am still figuring out what to do with it (going on 2 years so I admit I still don't know what to do, hehe). I lean more to scratch builds but I definitely have to do something with mine.
Best of Luck!
Cheers and Saludos
Thank you for the comment. :)
My having bought A becomes about two years ago.
The next...I want to customise the side panel,but no idea.
My friend in Japan also is doing a wonderful customizing HAF932.
Please see it;)
http://www.techpowerup.com/gallery/2820.html
User avatar
rikuntyudady
Vortex Dreamer
Postby masbuskado on Wed May 25, 2011 9:08 am
I really like the touch and details on the Cooler Master buttons! :wink:
Case Mod Competition 2012: Opprezzors: Annihilation Squad No. 2
User avatar
masbuskado
Praetorian Soldier
Postby rikuntyudady on Sun May 29, 2011 1:38 pm
masbuskado wrote:I really like the touch and details on the Cooler Master buttons! :wink:
Thank you for your comments. :)
User avatar
rikuntyudady
Vortex Dreamer
Postby FrenkieNL on Wed Jun 01, 2011 11:18 pm
Congratulations :cheers:
-= My cases @ casemodz.nl =-
User avatar
FrenkieNL
Centurion Officer
Postby KITSON CHAN on Thu Jun 02, 2011 3:27 am
:wink: Congratulations!
User avatar
KITSON CHAN
Centurion Officer
Postby rikuntyudady on Fri Jun 03, 2011 2:59 am
FrenkieNL wrote:Congratulations :cheers:
Thank you!!
I'm very very very grad. :)
User avatar
rikuntyudady
Vortex Dreamer
Postby rikuntyudady on Fri Jun 03, 2011 3:00 am
KITSON CHAN wrote::wink: Congratulations!
Thank you !!
I am very glad to be exhibited to COMPUTEX.
User avatar
rikuntyudady
Vortex Dreamer
Postby PaPang on Fri Jun 03, 2011 11:22 am
Hmmmmm, the top or bottom one? Grading according to CM standards:
Top) 71/100
Bottom) 92/100
The winner: MY GEAR by rikuntyudady.
Congrats and thanks for the link!
Cheers and Saludos
User avatar
PaPang
Stacker Hacker
Postby silent54 on Sun Oct 02, 2011 2:04 pm
rikuntyudady, great case mod. Took me a bit to find the mod again. I was looking at modding a side window on my HAF X with a HAF 932 side window but cutting it larger to show more of my machine when I add my water cool. Then I thought about opening it more and remembered your side panel mod. One question I have right now which isn't about the side window is about the two mods you did to conceal the 5.25 bay and PSU area. I see you used 3M DI-NOC Carbon as a covering material but what did you use to create the actual forms? Looks like some kind of plastic. Thanks
ASUS P8P67 Deluxe
Intel i5 2500k 3.3ghz (OCed - 4.5Ghz)
Corsair Cooling Hydro Series H50
8GB Gskill Ripjaw ddr3
Seagate Barracuda x 2 500GB RAID 0
WD Caviar Blue 500GB
GTX 460 1GB x 2
Win7 64
Coolermaster HAF X 942
User avatar
silent54
Aerogate Geek
Postby rikuntyudady on Tue Oct 25, 2011 4:56 am
silent54 wrote:rikuntyudady, great case mod. Took me a bit to find the mod again. I was looking at modding a side window on my HAF X with a HAF 932 side window but cutting it larger to show more of my machine when I add my water cool. Then I thought about opening it more and remembered your side panel mod. One question I have right now which isn't about the side window is about the two mods you did to conceal the 5.25 bay and PSU area. I see you used 3M DI-NOC Carbon as a covering material but what did you use to create the actual forms? Looks like some kind of plastic. Thanks
I have to apologize for the reply having become very late first to you. :cry:
The acrylic board is used for 5.25 inch bay hiding or power supply hiding as your imagination.
Those parts are cut into the form of a character, and it clips like a window, and is illuminating by LED from the reverse side.
In the back side, if milky acrylics is used, light will be emitted finely.
If the label etc. which were printed on milky acrylics are stuck, a character will appear.
Although this is a picture of "DF-85" which I created, the printed label is stuck on the portion of PSU hiding.
Moreover, 5.25inch bay hiding has cut "3M DI-NOC" into the form of a character.
Please refer also to the following URL.
http://www.overclock.net/case-mod-work-logs/971261-its-my-gear-haf932mod.html
It has appeared here and there frequently. :mrgreen:
User avatar
rikuntyudady
Vortex Dreamer
Postby silent54 on Tue Oct 25, 2011 9:19 am
Thanks for the response. No worries on the delay. It looked like acrylic but I couldn't tell. I'm actually in the begging stages of cutting mine and went with poly carbonate. Didn't see much difference in price but the poly is stronger. Won't be quite as rad as yours but will make a nice cover and accent the MB/water cooling area.
Had a question. For the life of me I can't remember what it was called but I had a Thermaltake case that came with a kit that you could print designs on transparent sheets and such that would be illuminated through an led strip. Did you make all of yours or was there a kit of some type that allows one to create the transparent designs to be lite up. I tried to search for something like it but haven't really found anything. Might do something like that on the two modded covers but that would be it. Not daring enough to really cut into my case. Thanks.
ASUS P8P67 Deluxe
GTX 460 1GB x 2
Win7 64
User avatar
silent54
Aerogate Geek
Postby rikuntyudady on Tue Oct 25, 2011 3:55 pm
silent54 wrote:Thanks for the response. No worries on the delay. It looked like acrylic but I couldn't tell. I'm actually in the begging stages of cutting mine and went with poly carbonate. Didn't see much difference in price but the poly is stronger. Won't be quite as rad as yours but will make a nice cover and accent the MB/water cooling area.
I did not know the kit of such Themaltake.
Although it is imagination, are they EL wire or EL sheet?
If it turns on electricity, there is the wire or sheet which emits light.
User avatar
rikuntyudady
Vortex Dreamer
Return to 2011 Case Mod Competition
Who is online
Users browsing this forum: No registered users and 1 guest
