THErMOnUCLeAR_2011 CM Case Mod Competition Entry( Finished )
Showcase your mods for the world to see! http://www.coolermaster.com/casemod2011
Re: Almost Done_THErMOnUCLeAR_2011 CM Case Mod Competition Entry
Postby Longhorn1000 on Fri May 13, 2011 9:31 am
fits ;D
probably one of the hardest step......making them stick together in an angle
done
new one
sand it
had to put some weigh as the big piece kept tilting upwards
looks badass
the other side
next side
an hour later.......I had to get some glue as the hot glue gum finished
time for some paint job
and again, the base ( interior )
first coat ( matte black )
outer coat
done :D
ok then....this is for today... C ya and stay tuned tomorrow :D
Longhorn1000
Vortex Dreamer
Postby Longhorn1000 on Fri May 13, 2011 8:55 pm
wOOT !! uPDATES
here's the piece of bezel
twist off the scary sides
cut it into 3 parts
same thing with the other piece
I'm a JSF-35C fan :D
anyways, the 2 painted sides from yesterday
thanks to Bill Owen on Mnpctech, I now don't need to buy carbonfiber sheets, just paint them. You can search for it on youtube :D Mod Men Episode 2
done, now just have to wait
in the mean time, I'm gonna concentrate back onto the case itself
woot! I said lego.....here's lego :D
Bionicle Toa Mahri sets :D
Longhorn1000
Vortex Dreamer
but how am I gonna fit both of them together??
easy, cut 1/4 of the box on each of them
the saw!!!:devil-smi
measure the back end
roughly about 19.5 cm.........not the most accurate measurements but it will do
9.6/7 cm on the box which is needed to be cut off
mark it
and cut it
there we go
same with the other side
:D
will it fit?? that's the last prob
:P
at least 10 minutes passed.....
wow, looks great
hmm...a hole in the pipes??
cut those small pieces off and hope that they can fit
lets glue it up
Longhorn1000
Vortex Dreamer
Postby Longhorn1000 on Fri May 13, 2011 8:56 pm
sand it.......
fits :D
glued up and looking good
continued work...
sand the sides of the box
cut off excess glue drips
and ready for painting
letting it dry up......
meanwhile......the pvc pipes are finally back :D
a piece of unused acrylic
sand it and glue it
and yes, apply the glue to the pipes as well
done sticking and let it rest until the glue are dried up
final part
the coat is dried up and ready for more detailed coats
Longhorn1000
Vortex Dreamer
the side
done.....
now for the interior painting
the side doesn't look that great compared to the top though....
ok, more pics in one and a half hour. Comment, view or do anything you want while waiting :D
Longhorn1000
Vortex Dreamer
Postby Longhorn1000 on Fri May 13, 2011 10:05 pm
Oohh....First update session of today is about to end
now the other side again
:D :D
looking better and better
more clear coat
dried up and.......what am i gonna do with this.....it seems......lonely.....cold XD
the pvc pipes are done sticking
no ideas at all...
dried up......
I've got plans for ya
a shiny black coat of paint
somethings about to happen......O-O???
tadaa :D
gonna let it dry up first
while looking at the fan grill......I got an idea
the two plain grey sides
turn into
dried up and ready for exposure
added some special effects
looks nice :D
but with some more special effects, much better
ok then, this will be an end to my afternoon session. be sure to check back in the evening :D See ya'll
Longhorn1000
Vortex Dreamer
Postby Longhorn1000 on Sat May 14, 2011 8:44 am
ok, couldn't finish it in time. But at least I finished what I wanna do today :D
some holes.......not tight enough....had to fill it with glue
meanwhile, I've got plans for the other piece
yes, I'm gonna place the bezel into it
and stick it for sure
done
I don't know if you can see the big hole bezel or not...
paint matte black
ready for the other piece
done and what I have left to do is cut off the bezel........
and it equals to
the big holed bezel painted black on both sides
and weld it to the bezel
and there you have it........2 bad-:) side attachment
It's getting dark really quick here so I decided to do a little bit more
first, I wanna fill those holes and scary edges with glue
and do a little paint job
matte black
used some dark grey as the back intake
sorry for the delay....... but although the post might seem to be short, it had token me hours to finish the bezel thing. Hope you enjoy todays post and keep following as tomorrow is our grand finale !!!!
Finally, this is going to end :D
Longhorn1000
Vortex Dreamer
Postby Longhorn1000 on Sun May 15, 2011 1:32 am
so, screwed the fan to the case to make sure that it doesn't slip
fit the pieces to the case
measure the width of between the sides
approx 9 cm but I made it 11 cm so it will fit inside of them
clever thinking, cutting it out with a bottle attached to the back of it
fits perfectly
off for some paint job
dark grey
meanwhile, get some leftover pieces of card
drew the height and cut it
Longhorn1000
Vortex Dreamer
match it till the end of the case
mark it and cut it out
going to fit another piece at the back of both pieces
ok, change of plans...., I'll use the leftover of the lego box again :eek:
find a piece of cardboard ( leftovers ) and try to fit it there
fits nicely and stick it there
but hey there's more pvc pipes :D
I'll try fitting then there to cover it up
fits perfectly
looks nice too
then, paint it with dark grey again
which means that I'll have to modify the pieces again??
added some textures to the pipes
and paint the lego boxes too, where I'm pointing is going to be covered with yellow paint
and this one with matte black
there
my pics end here for now, continuing my work right away
Longhorn1000
Vortex Dreamer
paint the inside as well
I'm gonna cover up the painted area with some tape
so does this one
aha, carbon fiber paint scheme again :D
both of them covered up and ready for another coat
wooooo......
wrap it up
paint it in grey
begin our enhanced painting since I did the first coat
15 minutes later........
the paint is revealed and didn't gave a good product
lets do it the old way, cover it up
nice
give it some paint effects
and some clear coat
this one too
ahh, before I forget, the last 2 pieces
with grey
cover them up, including the newly coated clear paint . Nice XD
Longhorn1000
Vortex Dreamer
Postby Longhorn1000 on Sun May 15, 2011 12:35 pm
As you wish XD
so this is from the evening till late night lol
2 pieces of the cut out card
looking nice
I can see the finished look already
got a new tube of glue
ooh......nice effects
done
so em, the hole ( sorry, for that, loast my dialog
going to stick the pvc pipe to it
done
Longhorn1000
Vortex Dreamer
Postby Longhorn1000 on Sun May 15, 2011 12:36 pm
fit or not?
:D
so here's a piece of bezel which is leftover from last time's cuttings
and paint it in matte black
the 2 pieces of cards with added effects
I bet you think its acrylic or metal XD cuz they really looked like it XD
and again, the leftover bezel
with stripes
going to fit it into the hole
done
going to stick the card
put a weigh on it to make sure it sticks properly
looks awesome
and see the hole there, I'm gonna do something to it
remember the two pieces of acrylic I left before?
the one which is sanded (left) and another one known as X marks the spot
fit them here
sand mr x too
and give them a paint job
Longhorn1000
Vortex Dreamer
Postby Longhorn1000 on Sun May 15, 2011 12:37 pm
so the back of the attachment
with added effects
and a coat of clear paint
the 2 pieces of acrylic dried up and added effects and clear coat
ok, dried up
looks fantastic
this is one however is the intake of the attachment
so here's the cut out for the painted bezel I did just now, and I wanna fit it horizontally to the top
some double-sided tape will do the trick sticking it there while I weld it
done welding
aha, back to the original case
Longhorn1000
Vortex Dreamer
painted it with shiny black color
currently around 10.25 p.m when I'm painting
so, it looks great
some grey and yellow paint for the furnishing of the case and effects
done, you might not be able to see them in some pics
a clear coat
so, a piece of acrylic used for the front panel of the attachment
sand it and paint it
Longhorn1000
Vortex Dreamer
Postby Longhorn1000 on Sun May 15, 2011 12:38 pm
alright.......the pics are done uploading
so, from right to left
wires......screws and all that good stuff
case fans
mesh bezel and HDD slots
DVD Slots , PCIE Brackets
tha big guy
wrap both ends of the wires
for painting
3 of them black and the other 3 in yellow
painted the fan yellow
the stock 120mm fan that came with the case matte black
while waiting for it to dry, the piece of black painted acrylic is welded to the front of the attachment
Longhorn1000
Vortex Dreamer
PreviousNext
Return to 2011 Case Mod Competition
Who is online
Users browsing this forum: No registered users and 2 guests
