(2011 Case Mod Competition) cm 690 nvida asus rog
Showcase your mods for the world to see! http://www.coolermaster.com/casemod2011
Postby douglas vieira alves on Mon Mar 07, 2011 7:16 pm
this is the coolermaster 690 nvidia.
I will disassemble sanding and painting of yellow reagent uv
the result of the color was not expected, not nice yellow color of the reagent uv.
I decided to redo the painting again.
I will disassemble and paint flat black now.
User avatar
Aerogate Geek
Re: (2011 Case Mod Competition) cm 690 nvida asus rog
Postby douglas vieira alves on Mon Mar 07, 2011 7:33 pm
painted black and now it was beautiful.
I've now starting w / mounting hardware
on the front did a bar with an LED bar Colca hot tips on putting green LED
at the top I get this grid. and just leave the screen.
User avatar
Aerogate Geek
Postby douglas vieira alves on Mon Mar 07, 2011 7:45 pm
I'll make some stickers
BOUGHT A NEW AND WILL FIT VGA A WaterCooler
NEW 3870X2 VGA
:bounce:
User avatar
Aerogate Geek
Postby douglas vieira alves on Mon Mar 07, 2011 8:04 pm
MY HARDWARE READY IF YOU HAVE MORE IDEAS
KIT SIMPLE Watercooler
now only ride the new toy hehehe :cheers:
User avatar
Aerogate Geek
Postby douglas vieira alves on Tue Mar 08, 2011 8:11 am
User avatar
Aerogate Geek
Postby douglas vieira alves on Thu Mar 10, 2011 7:09 am
ola,ja comesei fazer a montagem das peças e do wtaer cooler,ja p/ finalizar meu prejeto.
aki fiz um suporte com barra de resco e fiz um acabamento com uns cano de aluminium.
o puporte vai des do watercooler ater o fan 12 da trazeira.
nos fans coloquei os cano de aluminium p/ acompanhar o suporte.do watercooler
User avatar
Aerogate Geek
Postby douglas vieira alves on Thu Mar 10, 2011 7:23 am
essa mangueira da direito e na ponta ta meio fazia é p/ abastecer o sistema
User avatar
Aerogate Geek
Postby douglas vieira alves on Thu Mar 10, 2011 12:22 pm
resumido tudo tai minha montagem do meu pc.
User avatar
Aerogate Geek
Postby maestro0428 on Thu Mar 10, 2011 4:31 pm
You have an Nvidia case but an ATI card? Do you plan to change the theme to AMD?
maestro0428
Aerogate Geek
Return to 2011 Case Mod Competition
Who is online
Users browsing this forum: No registered users and 1 guest
