----> Click here for the post with 48 of the final pictures ! <----
Now also linked to the original 3900x2600 photo's !
Hi there:)
I'm quite new to this forum, but since they liked my build at some Dutch hardware sites, i wanted to post it here too.
My other build came to an end and didn't know what to improve, but my old desk almost fell apart.
Really want to thank Pascal for his pc-in-a-desk idea. After seeing it I couldn't even sleep that night
I started sketching it with Google Sketchup
After 9 hours of non-stop drawing it finally had some shape.
Hardware to be used:
(Most of it comes out of my old build)
Intel Core i7 980X @ 4.5 Ghz
Corsair Dominator GT 6GB DDR3-2000 CL7 (Elpida) @ 2000 7-7-7-20-1T
ASUS Rampage III Extreme
2 x ASUS GTX580
ASUS Xense
Sennheiser Xense
Highpoint RocketRAID 3560 24x SATA-300 2 GB
Bigfoot Networks™ Killer™ 2100 Gaming Network Card
1x Intel 510 120GB
3x Corsair F60 raid0
6x Hitachi Deskstar 7K2000 2TB raid5
2x Optiarc AD-7241S-0B
2 x Coolermaster Silent Pro 700W
Dell U2711 27″ IPS
2x Dell 1703 FPt 17″ portrait
Blocks
1 x EK Supreme HF Nickel CPU Block
2 x EK-FC580 GTX – Nickel
2 x EK-FC580 GTX Backplate – Nickel plated
1 x EK RAM Dominator Nickel
1 x EK-FB RE3 – Nickel
1 x EK-FB RE3 – TOP Acetal – Level 2
2 x Bitspower HDD Acetal Liquid Cooling Block – Silver
Pumps
2 x Laing D5-MCP655
2 x Bitspower D5/MCP655 Mod Pump Top V2
2 x Bitspower Black Sparkle D5/MCP655 Mod Kit
Reservoir
1 x Aquacomputer Aquatube G1/4 brass
Radiator
1 x Aquacomputer evo 1080
Fans
6 x Nanoxia DX Series 120MM DX12 - 1200RPM @ 5V
11 x Scythe Gentle Typhoon 120MM 1450RPM @ 12V
Fittings etc
24 x Bitspower Black Sparkle Multi-Link (SLI/CF) Adapter
16 x Bitspower Black Sparkle G1/4 Rotary 90 Degree IG1/4 Adapter
12 x Bitspower Black Sparkle G1/4 naar G1/4 (2x OD) Verbindingsstuk
10 x Bitspower Black Sparkle G1/4 Stop Fitting
8 x Bitspower Black Sparkle 13MM (1/2) Schroeffitting – G1/4
6 x Bitspower Black Sparkle G1/4 Rotary 90 Degree ID 1/4 Adapter
6 x Bitspower Black Sparkle G1/4 IG1/4 Extender
4 x Bitspower Black Sparkle G1/4 Five Rotary Snake-Style Dual IG1/4 Adapter
4 x Bitspower Black Sparkle G1/4 Rotary 45 Degree IG1/4 Adapter
2 x Bitspower Black Sparkle G1/4 Triple Rotary Mini Snake-Style Dual IG1/4 Adapter
1 x Bitspower Black Sparkle G1/4 Triple Rotary Snake-Style Dual IG1/4 Adapter
1 x Bitspower Black Sparkle G1/4 Rotary IG1/4 Extender
5 x Bitspower Crystal Link Tube For 5-Slots (SLI/CF)
8 x Bitspower Silver Shining 2xG1/4″ Fillport
2 x Bitspower Silver Shining G1/4 naar G1/4 (2x OD) Verbindingsstuk Mini
2 x Bitspower Matt Black 2xG1/4″ Fillport
2 x Bitspower Matt Black 13MM (1/2)Schroeffitting – G1/4
1 x Koolance INS-FM17 Coolant Flow Meter & Adapter Board INS-FM17
2 x Thermosensor G1/4 2x ID In-Line met Display (blue)
2 x Colder 13MM (1/2) Snelkoppeling Set
2 m Tygon R3400 1/2 ID Black
2 m Tygon R3603 1/2 ID Clear
3 L Feser One Cooling Fluid – UV Acid Green
I'm also gonna use my old cooling again since it works superb.
It's a 1080 radiator under my floor from my house, right in the corner where my pc is.
My water temperature in wintertime is around 18 degrees, in the summer it's around 23 degrees.
Here some Youtube movies:
Underground radiator
The Final Fill-up
Silence of the L3p D3sk
Sponsored by:
