TRON CM Final Pics
Showcase your mods for the world to see! http://www.coolermaster.com/casemod2011
TRON CM Final Pics
Postby Boddaker on Mon Feb 21, 2011 12:38 am
Details coming soon...
User avatar
Boddaker
2006 CM Case Modding Winner
Re: TRON CM
Postby PaPang on Mon Feb 21, 2011 7:04 pm
Wow, if the logo is anything like the final product, it will be astounding! Time is tight but it will be worth it, so lots of luck and hope all comes out as it should.
Cheers and Saludos
P.D. Think Jeffrey will compete?
Kick butt both ways: at the office and at home with Papang BizRigs!
Brought to you from Cancun, Mexico by http://www.modding.com.mx!
User avatar
PaPang
Stacker Hacker
Re: TRON CM
Postby ArgOs on Tue Feb 22, 2011 3:37 pm
Tron is one of my favorite films, the original approach my more to computers, I want to see the evolution of this work.
User avatar
ArgOs
Vortex Dreamer
Re: TRON CM
Postby shiryu_libra on Wed Feb 23, 2011 1:30 pm
here till the end bro... Tron 4 ever
[font=Verdana]Modding team!! Viva La Revolution!![/font]
[quote=Xtreme-Station]MSI 870A-G54/AMD Phenom II X6 1055T/Asus ENGTX 460 DirectCU 1GB/OCZ Reapers HPC 8GB 1600Mhz[/quote]
User avatar
shiryu_libra
Aerogate Geek
Re: TRON CM
Postby Boddaker on Sun Feb 27, 2011 10:49 am
Been working in Sketchup for the last week, building a mockup of the lightcycle suitable for housing a full ATX system with watercooling. It ended up being 40" long, but relatively short. As for the design, I didn't want to make a spot-on replica of the bike, so I went with my layered acrylic method, with just a few skinned areas around the wheels and top. This allows me to hide more components inside as well. Anyway, on with the mockups:
Upon removing some layers, you can see the initial motherboard placement and other components.
To give you a better idea of size, I placed a Cooler Master Cosmos case next to it.
PRELIMINARY PARTS LIST
EVGA X58 Motherboard
Intel i7 965 processor
EVGA GTX570 video cards in SLI
Crucial SSD
Crucial Ballistix memory
Pioneer Slimline slot load DVD drive
Cooler Master Silent Gold 850W Power Supply (qualifying product)
Dual bay reservoir by Primochill
Other watercooling parts TBD
I'm planning something special for the front radiator, more on that later. ;-)
So that's the basic plan, I'll be adding more detail as I go along. Good luck to everyone, this is going to be a great contest with many amazing entries! :D
User avatar
Boddaker
Re: TRON CM
Postby Tortured_soul on Sun Feb 27, 2011 3:48 pm
0_0
User avatar
Tortured_soul
Vortex Dreamer
Re: TRON CM
Postby alex_msi on Sun Feb 27, 2011 4:29 pm
:thumbup:
User avatar
alex_msi
Aerogate Geek
Re: TRON CM
Postby pcjunkie209 on Sun Feb 27, 2011 5:20 pm
Very nice! Can't wait.
'I would rather be gaming" grunts-clan.com
http://pcjunkiemods.com
User avatar
pcjunkie209
CM Beta Tester
Re: TRON CM
Postby shiryu_libra on Sun Feb 27, 2011 6:40 pm
oh my lord
gonna be outrageous :cheers:
User avatar
shiryu_libra
Aerogate Geek
Re: TRON CM
Postby PaPang on Fri Mar 04, 2011 7:22 pm
If it is watercooled, it's a keeper!
Cheers and Saludos
User avatar
PaPang
Stacker Hacker
Re: TRON CM
Postby Boddaker on Sun Mar 06, 2011 10:14 pm
Ok, got the acrylic parts list finalized, but before I send it off to the laser, I figured I should double check my measurements by making a 1/2-size model. I went back and rearranged some things to make room for fans and to facilitate better airflow.
Here's an overall look at the main acrylic parts. There are many more smaller pieces, spacers, and tubes that I didn't bother itemizing for the mockup.
First I thought I would print out a full-size outline of the bike with a picture of the motherboard in place.
Then I tested the 1:1 scale with an actual ATX board, and my qualifying product, a Cooler Master Silent Pro 850w power supply. :)
Final overall length is 38".
After getting a glimpse of the actual size, I proceeded to make the 1/2 size model. I only cut out the more important layers surrounding the components.
Peering down into the component area, you can see the lower IO plate.
The 1/2 size motherboard with two GTX580's in SLI: :D
The mobo and cards in place:
So far so good. Looks like things might actually fit as hoped. I'll go through the parts one more time and add some cable pass-through's and tubing holes, then I can finally send it off. Next update will show the acrylic parts when I get them in. 'Til then!
User avatar
Boddaker
Re: TRON CM
Postby pcjunkie209 on Sun Mar 06, 2011 11:36 pm
Very nice. Can't wait to see finished product.
User avatar
pcjunkie209
CM Beta Tester
Re: TRON CM
Postby mgyovanni on Wed Mar 09, 2011 7:53 am
I am anxious to see this project completed, good luck to us!
[<o>]"DMC", the casemod that won more votes in the category Tower mod in CMC2011 [<o>]
viewtopic.php?f=49&t=14715
User avatar
mgyovanni
Vortex Dreamer
Re: TRON CM
Postby Tech-Daddy on Sat Mar 12, 2011 10:04 am
Go get em Bod.... I absolutely can *not* wait to see how you bust this out!
Your past builds in a similar vein have always come out right on, this one should be OUT-frikken-STANDING!!!
:cheers:
Subscribed
-=TD
User avatar
Tech-Daddy
Elite Modder
Re: TRON CM
Postby PaPang on Mon Mar 14, 2011 10:08 am
An old-school mockup! My, my, as goof-proof as it gets and its looks great!
Cheers and Saludos
User avatar
PaPang
Stacker Hacker
Next
Return to 2011 Case Mod Competition
Who is online
Users browsing this forum: No registered users and 2 guests
