ATCS 840 Side window panel
Post your ideas or suggestions you wish to see Cooler Master future product release...
Moderator: CM Moderator
Postby Griffin on Sun Dec 14, 2008 3:59 am
Well this is a feature I know id certainly like to see, and reading through some other forums it seems im not alone.
Griffin
Aerogate Geek
Re: ATCS 840 Side window panel
Postby Rudieman on Mon Dec 15, 2008 7:09 pm
I just asked my PM and he told me there is going to be one but he is currently not working on it yet. So it might take some time before they are sold.
Rudieman
CMNL Support
Postby BrettWms on Tue Jan 20, 2009 4:03 pm
I personally don't care about the window thing, but what I do care about is all the dead air space that could be resolved by a side-mounted fan. Any idea if that will be coming at all? There are ways to add one of your 200+ mm fans, and make it look classy as well. :)
CM Stacker 830 Evo SE
eVGA x58 SLI Mobo
i7 920 @ 4.00Ghz
CM v8 (@ 70c under load)
6G Corsair
eVGA GTX 295
2x 80G (10k), 1x 300G Seagate, 1x 640G WD
X-Fi Sound Card
LG BluRay/HD-DVD ROM
1000W Ultra PSU
Windows Vista Ultimate SP1 64-bit
User avatar
BrettWms
CM Beta Tester
Postby biggatomic on Tue Jan 20, 2009 9:57 pm
yeah my 840 needs a window bad!!!
Corsair Obsidian 800D
Thor's Hammer
EVGA E759 CLASSIFIED LIMITED EDITION
Intel® Core™ i7 Processor 920
12 gigs DDR3-1600
Asus XONAR HDAV 1.3 Deluxe
(2) VELOCIRAPTOR (raid 0) & (4) 2TB WD Caviar
(2)gtx275 Arctic Cooling Accelero XTREME cooled
User avatar
biggatomic
CM Beta Tester
Postby Icejon on Wed Jan 21, 2009 3:26 am
It is coming soon... Save up and give us 4.5 weeks and you will find it on the CM store.
Beta testing moderator - Have a Better Day Everyday
Strength, Security & Control
User avatar
Icejon
CM MKT
Postby biggatomic on Wed Jan 21, 2009 3:47 am
Icejon wrote:It is coming soon... Save up and give us 4.5 weeks and you will find it on the CM store.
thanks :bounce: :bounce: :bounce:
Thor's Hammer
12 gigs DDR3-1600
User avatar
biggatomic
CM Beta Tester
Postby BrettWms on Wed Jan 21, 2009 7:16 am
Does it have a fan? (say yes, say yes, say yes)
eVGA x58 SLI Mobo
i7 920 @ 4.00Ghz
6G Corsair
eVGA GTX 295
X-Fi Sound Card
1000W Ultra PSU
User avatar
BrettWms
CM Beta Tester
Postby knud on Wed Jan 21, 2009 10:08 pm
No, it will not have a fan.
We want to keep the clean look :)
CM Parts shop
QX6850 @ 3.2 Ghz | Abit IP35pro | OCZ DDR2-800 4gb Reaper | Leadtek 8800GTX | WD Raptor 74GB | ATCS 840 | CM Real Power M700 | 1x CM Aerogate 3 | Z600 Black
User avatar
knud
Cooler than Cooler Master!
Postby Griffin on Thu Jan 22, 2009 12:50 am
Is it safe to assume it's a full sized window? Or have you gone with a different shape?
Griffin
Aerogate Geek
Postby neverXmiss on Thu Jan 22, 2009 3:31 am
To get an idea on how the window is going to look, look at the CES pics of our products:
http://www.overclockersclub.com/reviews/ces2009/18.htm
minus the the logos and stuff of course.
CPU: Intel Core i7 920 @ 3.20GHZ
CPU Cooler: CM V8
Motherboard: Asus P6T Deluxe
GPU: MSI Geforce GTX 260
RAM: Corsair XMS 3 GB Triple Channel + Crucial Ballistix 3GB
PSU: CM UCP 1100W
Case: Storm Sniper Black Edition
NA Division Live Chat
User avatar
neverXmiss
CMUSA Customer Support
Postby knud on Thu Jan 22, 2009 11:24 pm
It looks even better than that :D
You will see it very soon :)
CM Parts shop
User avatar
knud
Postby BrettWms on Fri Jan 23, 2009 3:50 pm
knud wrote:No, it will not have a fan.
Bleh.. :x The only bad thing about this case is the lack of air flow in regards to CPU cooling. There's just not enough air reaching it.... =\
Time to mod it myself I guess. /sigh
eVGA x58 SLI Mobo
i7 920 @ 4.00Ghz
6G Corsair
eVGA GTX 295
X-Fi Sound Card
1000W Ultra PSU
User avatar
BrettWms
CM Beta Tester
Postby knud on Sat Jan 24, 2009 12:04 am
Lack of airflow for the CPU Cooling?
Didn't you notice the 2x 200mm fans on top of the case? :P
About the side panel, it's a matter of taste I guess.
CM Parts shop
User avatar
knud
Postby VenomousDesigns on Fri Jan 30, 2009 2:04 am
I have to admit, an additional purchase of a side panel WITH addition fan/cooling options would be GREATLY suggested by me and NUMEROUS other users (I can point you in the direction of a couple reviews that mention the lack of them playing a huge role in higher temperatures compared to the HAF 932).
One such review can be found here in a recent review of your upcoming Sniper case, from the pictures you can see the HAF 932 totally outperforming the ATCS 840 in all benchmarks simply due to its side mounted fan: http://www.bit-tech.net/hardware/cases/ ... r-review/4
Also another quote from a review reads:
We think the difference in performance between our top performers and the ATCS 840 has likely been caused by the sheer size of the case. All our other top performing cases, the HAF 932 especially, tightly surround the CPU and GPU with exhaust or intake fans, drawing heat directly off of, or blowing cool air directly onto the CPU cooler and our test set up’s passive GPU heatsink.
The problem is that the ATCS 840 has become a victim of its size; the primary 230mm cooling fans are placed comparatively far away from the core hardware and so have limited effect in directing airflow off of or on to the sources of heat.
Could member of CM please reply on the POSSIBILITY of a side fan panel - this will be the decider in me purchasing the HAF 932 or the ATCS 840 tomorrow.
VenomousDesigns
LED Head
Postby neverXmiss on Fri Jan 30, 2009 5:49 am
Anything is possible, but right it looks like its going to be a full window, no fan, side panel. However that could change.
CPU Cooler: CM V8
PSU: CM UCP 1100W
User avatar
neverXmiss
Next
Return to Product Suggestions
Who is online
Users browsing this forum: No registered users and 1 guest
