Project G5 PC - by Canadian Falcon
World wide contests
Moderator: CM Moderator
Postby KitKatBar on Mon Nov 20, 2006 4:50 pm
Project name : Project G5 PC
Project Theme : LAN Party Case
Cooler Master Products :
2x CM Neon Red 80mm Case Fan’s 80mm Red Case Fan
2x CM Black 80mm Case Fan’s 80mm case fan
1x CM Northbridge cooler PAC-PO1-UB Northbridge Cooler
the first half of the worklog is hosted on
http://www.mashie.org/forums/showthread ... ge=2&pp=10
This project started with a MAC G5 Case
http://img201.imageshack.us/img201/9687/img3456cb0.jpg
I immediately started ripping it apart, Since I wanted a window in my case, the first thing I did was start cutting out the side panel’s new porthole
This Was met with a lot of broken Dremel bits, but I persisted, and was eventually left with this
http://img201.imageshack.us/img201/2889/img3470ed5.jpg
Rather impressed with my window I then turned to the top. Seeing that I wanted to put a handle of my own on top, I pulled out my Die grinder and removed the top handles that originally came on the case.
http://img201.imageshack.us/img201/3070/img3473gb2.jpg
I then Started to cut out my original idea for the top, it was going to be this
http://img48.imageshack.us/img48/9128/t ... llecg2.jpg
Unfortunately the Plexiglas wasn’t quite strong enough and broke in a couple of places, so I went to my backup plan, carving my falcon logo right out of the case. Good idea, bad application, again back to the dremel, and ruining cutting discs
http://img66.imageshack.us/img66/5320/img3813ok5.jpg
I then sanded it, and made it look a little nicer. Then I moved on to the handle.
http://img213.imageshack.us/img213/2336/img3814ko1.jpg
The foam went pretty well, and it didn’t quite turn out the way I had wanted, but it went alright.
Then came fibre glassing.
http://img214.imageshack.us/img214/4897/img3843uw5.jpg
Which went well, I got my handle done as well as the door. I then painted the Front door for the case.
http://img204.imageshack.us/img204/503/ ... ingxc8.jpg
One of the few things I’m overly happy with. The Door came out almost exactly like my drawing. I then moved on to painting the top falcon
http://img297.imageshack.us/img297/6886/toppaintvu6.jpg
You can see the nice red glow from the 2 cooler master neon red case fans in this picture. (little blurry)
http://img297.imageshack.us/img297/2963 ... lowty7.jpg
I then attached the front door, and was done, you can see a little bit of the red glow on the bottom of my hand
http://img213.imageshack.us/img213/5967/img3923je1.jpg
Just for note, although it’s a little hard to see the sign on the bottom says “2006 Cooler master case mod contest --- Project G5 Dorian Oâ€
User avatar
KitKatBar
Admin/Marketing Support
Return to Global Contest Area
Who is online
Users browsing this forum: No registered users and 2 guests
