I plan to by some new hardware soon but I’m not sure if I also should go for Vista.
What would you thing would be the best Vista or XP, and why?
Thanks Coolone
Moderator: CM Moderator
Coolone wrote:What would you thing would be the best Vista or XP and why?
merovingian wrote:Crap is the future, embrace it!
Maxession wrote:The persons with their new laptops that came with Vista preinstalled, have all changed back to XP on their.
Viper wrote:i still want to comment on the memory hog part though...
yes it uses more ram then XP, but which pc ships with less then a gig these days? which is what you need to run it smoothly.
and yes, if you have more - and even with only 1 gig for that matter - vista will use more then it really needs. who ever said that is a bad thing?
RAM is not a resource. you should think of RAM as nothing more than a cache. and an empty cache, is just a waste of resources. vista will use any ram not needed by other programs to pre-cache parts of often used programs and libraries to lower access times when they are required. if a program needs more ram, the os simply dumps a part of the pre-cache.
and for the record, i am not some vista fanboy, i m a just .net programmer.
Viper wrote:When all you want to do is games, there s no reason to go to vista atm, unless you need the DX10 capabilities...
Users browsing this forum: No registered users and 1 guest
