EsaT wrote:Most cases don't anymore have real case airflow because holes in everywhere remove that possibility.
I can't speak for most cases since I've primarily been using Cooler Master cases for building, but I don't know. It seems to me that airflow is a high priority with Cooler Master cases at least, and the majority of their cases have been designed around that. Even looking at the HAF 932, it may have many, many openings, but in my examinations of the air flowing through when fired up, there is a logical flow within the design.
Now, I'm not saying you're incorrect. Not in the least since I've just really begun looking at cooling overall since around May of last year, but I still believe that case design still takes airflow into high consideration in their design. I'm sure the other side to that coin is the builder ensuring somewhat decent cable routing and placement of components, but overall, I truly believe airflow is still a priority.
Anyone else care to chime in with their thoughts? I'd really like to hear more.
