NotePal Ax Notebook Cooler Announced
Important news and announcements about the website, forum, and Cooler Master products.
Moderator: CM Moderator
Postby Maxession on Wed Aug 12, 2009 3:57 am
Image Image Image
Image Image Image
Features wrote: * Uniquely designed built-in fan for intake of airflow from all sides.
* 140mm fan for superior silent airflow.
* Fan-speed control knob for adjustable settings.
* Adjustable foot stands for comfortable viewing angle.
* Fits most 12"~15.4" laptops perfectly (up to 17").
Specifications wrote:Material Metal mesh and plastic
Dimension (W / H / D) 383 x 46 x 289 mm ; 15.1 x 1.8 x 11.4 inches
Weight 860g
Operation degree 7 degree & 11 degree
Rated Voltage 5 VDC
USB Port USB2.0/1.1 x 2 (input x 1; output x 1)
Compatibility Supports all 12"~15.4" laptops, up to 17"
Fan Dimension 140 x 140 x 15 mm ; 5.5 x 5.5 x 0.6 inches
Fan Speed 700 - 1400 RPM
Bearing Type Rifle bearing
Fan Noise Level (dB-A) 15dBA (Min)
Fan Life Expectancy 40,000 hours
Cable Length 600mm
Further details, pictures and specifications can be found at the Product page.
User avatar
Maxession
CM Moderator
Return to News & Announcements
Who is online
Users browsing this forum: No registered users and 2 guests
cron
